Just finished my z6 swap...some problems
Hey guys, I just finished me d16z6 swap and I am having some issues.
First problem is that there seems to be a lot of air in the coolant. Let my car idle with the radiator cap off, and sometimes revving it to 2500 rpm, but he bubbles keep coming. I have done this about 3 times.
Second problem is the idle at full warm up bouncing around between 800-1000rpm. Does this problem have to do with air in my coolant?
Thanks
Thanks
Make sure your heater control is set on full heat, and dbl check all your hoses to make sure you dont have a leak. Ive had to bleed coolant systems for 15-20 minutes before! More than likely air in your coolant is causing the idle to fluctuate.. ive also had a similiar problem when my TPS got out of adjustment (if its ever been removed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khmi »</TD></TR><TR><TD CLASS="quote">Hey guys, I just finished me d16z6 swap and I am having some issues.
Thanks</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 »</TD></TR><TR><TD CLASS="quote">Make sure your heater control is set on full heat, and dbl check all your hoses to make sure you dont have a leak. Ive had to bleed coolant systems for 15-20 minutes before! More than likely air in your coolant is causing the idle to fluctuate.. ive also had a similiar problem when my TPS got out of adjustment (if its ever been removed)</TD></TR></TABLE>
Yeah had to replace the TPS, motor didnt come with TB.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">If you are positive you have removed all the air for the system you may want to look into a leaking headgasket allowing combustion gases to escape into your coolant.</TD></TR></TABLE>
Changed the headgasket before putting the motor in.
Schultzie
Aug 11, 2007 02:32 PM
entityzero
Mar 26, 2007 07:44 PM
-[95cxhatch]-
Feb 28, 2004 08:20 AM
