tach no work after swap
Old Jan 21, 2006 | 10:01 AM
1sikhatch's Avatar
Default tach no work after swap
i just swapped out my z6 for a b16 and now my tach doesnt work, everything else in the cluster is working perfectly but the tach wont work. where do i start trouble shooting?
Old Jan 21, 2006 | 10:04 AM
dohcMONSTER's Avatar
Default Re: tach no work after swap (1sikhatch)
check your alt. your speedo and alt are on the same fuse
Old Jan 21, 2006 | 10:05 AM
1dopesi's Avatar
I'm not sure if a b16 has a speed sensor but I had the same problm with my h22 eg swap until I relized it was unplugged.
Old Jan 21, 2006 | 11:24 AM
hatchi's Avatar
what harness did you use??
Old Jan 21, 2006 | 01:19 PM
1sikhatch's Avatar
Default Re: tach no work after swap (hatchi)
my speedo is working, its the tach thats not working. and i used the harness from the si with the eg plugs on it, but the guy i got it from said his tach worked perfectly in his car
Old Jan 22, 2006 | 05:40 AM
1sikhatch's Avatar
anyone the tach wire color by the shock tower?
Old Jan 22, 2006 | 06:30 PM
1sikhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">anyone the tach wire color by the shock tower?</TD></TR></TABLE>
anyone?
Old Feb 2, 2006 | 12:55 PM
Turbo_Mike's Avatar
figure it out?
i'm having the same problem on my 00 ls swap with obd2 harness
Old Feb 6, 2006 | 10:06 AM
Turbo_Mike's Avatar
Default Re: tach no work after swap (MIKE JONES)
up for figuring out this problem
Maximus
Jun 5, 2025 09:26 AM
jerseyh22accord
Jun 18, 2010 06:48 PM
eg-ed
Nov 26, 2006 03:59 PM
NsX_CrX
Oct 27, 2005 08:57 PM
lowcivex
Apr 13, 2003 10:57 AM
