Car overheated
Old Jan 20, 2006 | 06:26 PM
Integra Integra's Avatar
Default Car overheated
My car overheated today (stayed below the red a little over the center mark) and I pulled over checked coolant and it was fine reserve tank had coolant and as I drove it would cool but when I was stopped at a light it would climb up, what do you think caused this? Possily air bubbles? I just removed the cap in my garage let it idle to get it up to center point and bubbles were rising to the top what that my issue? I mean now I can idle for a while and I won't over heat and my heat is nice and warm already.. should i worry
Cliffs: Car overheated and when I got home I removed rad cap and bubble came up to the top is everything OK was it just air?
Thanks
Old Jan 20, 2006 | 06:32 PM
teg racer 877's Avatar
Default Re: Car overheated (Integra Integra)
prolly just air, bleed the system with the bleeder screw if you have it, dont worry, unless it happens again.
Old Jan 20, 2006 | 09:20 PM
GoCarInteg's Avatar
Default Re: Car overheated (teg racer 877)
when was the last time you checked if your thermostat was working?
Old Jan 21, 2006 | 03:38 AM
Default Re: Car overheated (GoCarInteg)
Well I haven't checked in a while but I see my fans are turning on after a while... and I got heat in the car..
Old Jan 21, 2006 | 06:17 AM
Ichigo's Avatar
I agree with GOcarinteg go check your thermostat. It is probably that or your radiator.
Old Jan 21, 2006 | 10:47 AM
Default Re: (R34lude)
Yeah I will replace my stat anyway its a cheap part, my rad looks fine I can't see any visible cracks. I will pressure test it this week sometime
Old Jan 23, 2006 | 03:48 AM
haveaNOSday's Avatar
Rad fan!
Old Jan 23, 2006 | 04:00 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaNOSday &raquo;</TD></TR><TR><TD CLASS="quote">Rad fan!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Integra &raquo;</TD></TR><TR><TD CLASS="quote">Well I haven't checked in a while but I see my fans are turning on after a while... and I got heat in the car..</TD></TR></TABLE>
it could have been the air bubbles, but check your thermostat like they said.
Old Jan 23, 2006 | 04:13 AM
right! must have skiped that one
Old Jan 23, 2006 | 06:46 AM
Default Re: (haveaNOSday)
I will check my tstat thanks!
1fastvtec
Jan 26, 2015 05:12 PM
turbo-crx
Jun 19, 2008 09:13 AM
WRTEG
Mar 18, 2004 05:51 AM
DsCivicEx
Feb 12, 2004 04:52 PM
intekragsr
Nov 11, 2002 05:58 PM
