boring a b18a1 block?
Old Jan 20, 2006 | 12:00 AM
bigwill_2004's Avatar
Default boring a b18a1 block?
90 gs...i dont mean to bother yall but i got my engine out and am taking it up there tomorrow to get this work done, ok, if i get the 20 over pistons, how much should i have it bored. 20 or 25 over?, and do yall know how much hp gain 20 over is?
Old Jan 20, 2006 | 08:03 AM
97turboteg's Avatar
Default Re: boring a b18a1 block? (bigwill_2004)
.20 over bore...20 over....i got my engine bored 20 over also...bore doesnt really add hp, its more about displacement. Whats the main reason your even boring your motor? if you take ur engine apart and the miles are getting up there you should also change all gaskets, bearings, water pump, resurface your head, and maybe a valve job, you dont just bore your engine....
Old Jan 20, 2006 | 06:56 PM
Default Re: boring a b18a1 block? (97turboteg)
i didnt say i was just boring the block. im buyin a full kit all new gaskets, pistons, rings, ets. i wanted to bore .040, tryin to add more hp, engine will later have turbo application. or nos, its a teggy drag car. how much hp are we talkin about with .040 over bore pistons?
Old Jan 20, 2006 | 07:49 PM
mattcivic's Avatar
if it were me and i wasnt sleeving the block for boost i would bore cylinders as little as possible so u dont compromise the integrity of them.
Old Jan 25, 2006 | 11:42 AM
97turboteg's Avatar
Default Re: boring a b18a1 block? (mattcivic)
boring isnt meant for power really, and duh your not just going to get your engine bored...pistons have to fit snug...i dont get why you want to bore the hell out of your motor. its just a little extra displacement, and like the other guy said, if ur going to use nos or forced induction, you wont want .40 over. thats too much, that means the pistons will be closer together and can ruin your block. its a drag car? whats it run? for the money, if you dont need pistons, you can make a lot more power out of other things...bore isnt like nos or anything. i think you have the wrong perspective on it...
Old Jan 25, 2006 | 12:06 PM
RX3's Avatar
RX3
Any good machine shop can do it for you. they bore the block to fit the pistons cast or forged makes a difference on the clearance's. I am sure they will want the pistons before the do the work.
Old Feb 1, 2006 | 01:47 PM
Circuit Star-29's Avatar
Default Re: boring a b18a1 block? (RX3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RX3 &raquo;</TD></TR><TR><TD CLASS="quote">Any good machine shop can do it for you. they bore the block to fit the pistons cast or forged makes a difference on the clearance's. I am sure they will want the pistons before the do the work.</TD></TR></TABLE>
ALWAYS....If a shop bores you block w/o pistons, they are FAWKING out of their head and do not know what the hell they're doing.
joethejoeman
Nov 26, 2006 10:19 AM
nos4a2si
May 16, 2005 08:27 AM
Cyber ITR
Apr 11, 2002 12:25 PM
Dorikamu
Mar 11, 2002 06:41 PM
BLKCRX
Feb 12, 2002 10:12 AM
