clutch master cylinder help
Old Jan 19, 2006 | 11:36 PM
dynastix9's Avatar
Default clutch master cylinder help
anyone know of a link or can anyone give me instructions on how to install and remove, would much appreciate thanks
Old Jan 20, 2006 | 12:52 AM
sol lovin's Avatar
Default Re: clutch master cylinder help (dynastix9)
tools needed:
socket, wrench
1. open your hood
2. stare at it for a while
3. do the work
Old Jan 20, 2006 | 01:05 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: clutch master cylinder help (sol lovin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol lovin &raquo;</TD></TR><TR><TD CLASS="quote">tools needed:
socket, wrench
1. open your hood
3. do the work</TD></TR></TABLE>
lol, yea its pretty straight forward man. Unbolt it, and bolt the new one in. Bleed.
Old Jan 20, 2006 | 03:52 AM
T-RO's Avatar
get a chiltons book. it explains it there. Its real easy, I just did it 2 weeks ago.
Old Jan 20, 2006 | 03:54 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (T-RO)
This will help a lot. Well, not rly. Maybe a little.
https://honda-tech.com/zerothread?id=1411146
Old Jan 20, 2006 | 05:47 AM
BryanPendleton's Avatar
Default Re: (litterbox)
I just replaced a leaking clutch master cylinder a few weeks ago. Took me all of 1 hour and 15 minutes to swap and bleed hydraulics. Would have been an hour, but the clutch line pipe fitting to the cylinder was buggered up and would not accept the size wrench it was suppose to.
Disconnect hydraulic line (line pipe wrenches are the best tool)
Disconnect cyinder piston rod from pedal (inside car). 1 bolt
Remove two bolts to unmount the master cylinder in engine bay.
Reverse for install
Bleed hydraulics.
The best tip though is buy this: I actually bough mine for $18 at their store.
http://www.harborfreight.com/c...92474
A vacuum bleeder kit. WONDERFUL TOOL! I have the clutch hydraulics completely purges with dot 4 fluid and air free in a matter of 5 minutes, all by myself. Not need for someone to be stomping on the clutch pedal to pump fluid through hydraulics.
hawtsoss
Oct 21, 2008 03:39 PM
mugenspoongsr
Jul 6, 2006 07:20 PM
NeWnMpR0VeD
Jun 17, 2006 11:46 AM
93H22A
Apr 9, 2004 10:46 PM
