ctr cams / itr cams confusion..
Old Jan 19, 2006 | 09:30 PM
integra95gsr's Avatar
Default ctr cams / itr cams confusion..
well ive recently been interested in upgrading my cams in my 95 GSR.. i know that the ctr cams are really good and the 00-01 itr cams are the same thing, correct?
i've been told 2 things. A)the cams are great for mid range power and have an awesome powerband, but i'll need to upgrade the IM. and B) If i dont upgrade my valvetrain i wont feel the cams at all, becz they dont make a difference till 8k. and i dont change the valvetrain i'll still have my 8,200k redline so its not worth it.. which is the truest statement..
the car has i/h/e
Old Jan 19, 2006 | 09:45 PM
iH8RICERZ's Avatar
Default Re: ctr cams / itr cams confusion.. (integra95gsr)
you can install itr/ctr cams in your stock gsr and still notice slight gains. You'll be safe if you dont rev past 8k rpm. From what I understand, the 98+ ITR cams are the same exact thing as the CTR cams. Upgrading the valve train just assures you from not overreving and doing damage to your head. As for the gains, don't expect a night and day difference, even if your using the stock gsr intake manifold or even if you convert to a single stage manifold, you'll only notice the difference in the high end. Hope that helps....
I've been running a ctr intake cam and gsr exhaust cam on my 94 gsr w/ stock valve train for the past 4 years...no problems what so ever.
Old Jan 20, 2006 | 03:11 AM
EnjoyTheRideDC2's Avatar
Default Re: ctr cams / itr cams confusion.. (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">you can install itr/ctr cams in your stock gsr and still notice slight gains. You'll be safe if you dont rev past 8k rpm. From what I understand, the 98+ ITR cams are the same exact thing as the CTR cams. Upgrading the valve train just assures you from not overreving and doing damage to your head. As for the gains, don't expect a night and day difference, even if your using the stock gsr intake manifold or even if you convert to a single stage manifold, you'll only notice the difference in the high end. Hope that helps....
I've been running a ctr intake cam and gsr exhaust cam on my 94 gsr w/ stock valve train for the past 4 years...no problems what so ever.</TD></TR></TABLE>
Great explanation.....Straight to the point and very true.
Old Jan 20, 2006 | 09:00 AM
Default Re: ctr cams / itr cams confusion.. (EnjoyTheRideDC2)
thanks alot, that def helped clear it up!
so do you think its worth it? becz i can only seem to find a ctr intake cam from hmotorsonline and i think it was $239. Should i spend that $200 else where on something i could more benefit from, and also is that a good price?
Old Jan 20, 2006 | 09:08 AM
iH8RICERZ's Avatar
if you search in the classifieds, you might be able to find a set of ctr or itr cams for $250-350... I originally paid $200 for my ctr intake cam from one of my buddies.
What are your future goals/plans with the car?
Old Jan 20, 2006 | 09:32 PM
future plans really depend on funds..
especially being a college kid its hard to say what i see in the future for a car. but i want an all motor beast one day..
Old Jan 21, 2006 | 01:40 PM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">From what I understand, the 98+ ITR cams are the same exact thing as the CTR cams. </TD></TR></TABLE>
This is incorrect, the 00-01 ITR cams are identical to CTR cams. The 97-99 have a less aggressive intake cam but the exhaust cams are the same.
Old Jan 21, 2006 | 02:37 PM
import810's Avatar
Default Re: ctr cams / itr cams confusion.. (White Smoke)
I picked up a set of ctr exhaust and intake cams for $300 total on here.
Old Jan 21, 2006 | 03:22 PM
i my honda
Global Mod
Default Re: ctr cams / itr cams confusion.. (import810)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 &raquo;</TD></TR><TR><TD CLASS="quote">I picked up a set of ctr exhaust and intake cams for $300 total on here.</TD></TR></TABLE>
Nice
Old Jan 21, 2006 | 05:53 PM
MJobe's Avatar
get both or dont do it at all....
i have CTR cams in my gsr swap and i noticed great gains
Old Jan 22, 2006 | 05:17 PM
if i did this would i need to change to itr valves?
what about the springs / retainers?
i heard that if i just get the itr intake side springs, i can use my gsr intake springs on my exhaust side, and just reuse the gsr retainers, is this false?
Old Jan 22, 2006 | 05:27 PM
import810's Avatar
Default Re: (integra95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr &raquo;</TD></TR><TR><TD CLASS="quote">if i did this would i need to change to itr valves?
i heard that if i just get the itr intake side springs, i can use my gsr intake springs on my exhaust side, and just reuse the gsr retainers, is this false?</TD></TR></TABLE>
thats what I'm doing it's good up to 8800rpm
Old Jan 22, 2006 | 05:38 PM
i my honda
Global Mod
You dont have to change out anything just dont rev it past ~8k with the stock springs.
Old Jan 22, 2006 | 06:02 PM
ive heard that if i dont change the springs then i wont be able to feel the cams at all..
Old Jan 22, 2006 | 06:43 PM
MJobe's Avatar
^^^ thats bull **** ......
i have gsr swap with i/h/e/chipped ecu
when i put the ctr cams in it REALLY woke up the motor.
keep in mind i didnt upgrade anything on the valvetrain i just keep my stock redline ..their great
EvanM1
18
Jun 9, 2010 09:41 PM
crackerjacker006
Aug 23, 2005 11:05 PM
compwc18
May 22, 2005 05:05 PM
dornon13
Jul 17, 2004 11:48 AM
B00ST2nR
Apr 17, 2002 01:26 PM
