quick question with a picture.
Old Jan 19, 2006 | 08:14 PM
rodvang's Avatar
Default quick question with a picture.
What is this hole for? the one in the red box.
Old Jan 19, 2006 | 08:16 PM
BauleyCivic's Avatar
Risky Business
Default Re: quick question with a picture. (rodvang)
32mm nut that can be removed with the end of a 3/8" ratchet
Behind it is the snapring that holds the transmission case to the mainshaft (or countershaft, I can't remember)
Old Jan 19, 2006 | 08:18 PM
rodvang's Avatar
Default Re: quick question with a picture. (BauleyCivic)
what fluid comes out of it? and what would happen if the edge broke off from over tightening...and would could be done about it...
Old Jan 19, 2006 | 08:49 PM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodvang &raquo;</TD></TR><TR><TD CLASS="quote">what fluid comes out of it? and what would happen if the edge broke off from over tightening...and would could be done about it... </TD></TR></TABLE>
i take it that is what you did?
Old Jan 19, 2006 | 08:52 PM
Hybrid96EK's Avatar
Tranny fluid comes out of it. If it leaks, your hosed. Needs to be fixed. New case usually.
Old Jan 19, 2006 | 08:56 PM
atomik speed's Avatar
Default Re: quick question with a picture. (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Tranny fluid comes out of it. If it leaks, your hosed. Needs to be fixed. New case usually.</TD></TR></TABLE>
doesnt sound too good.............what tranny are u running? b series or d?
Old Jan 19, 2006 | 09:06 PM
stripery2bk's Avatar
between the two white circles, on my car, there is some liquid.... any clue why?
Old Jan 19, 2006 | 09:07 PM
Hybrid96EK's Avatar
Default Re: (stripery2bk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripery2bk &raquo;</TD></TR><TR><TD CLASS="quote">between the two white circles, on my car, there is some liquid.... any clue why?</TD></TR></TABLE>
Axle seal is bad
Old Jan 19, 2006 | 09:08 PM
fixable? How much?
Old Jan 19, 2006 | 09:16 PM
rodvang's Avatar
couldnt just use jb weld or somethin to put it back on
Old Jan 19, 2006 | 09:19 PM
fastrunner's Avatar
$5 for the seal, you need a pry bar and socket set, remove the axle, carefully remove seal. Dont gouge the area around the seal. wipe the area dry and reinstall a new seal and then install your axle.
Oh wait buy a new tranny or case and do that first. Or cheap way out... spray the area around the red circle with engine cleaner, make sure its dry then apply devcon liberally, sealing the <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">32mm nut that can be removed with the end of a 3/8" ratchet</TD></TR></TABLE>
goodluck.
mmmsushi
Oct 23, 2005 09:37 AM
builthatch
Aug 17, 2005 05:37 AM
Circuit Star-29
Jun 2, 2005 03:07 PM
5spdIntegra
Mar 29, 2004 08:52 PM
sudds
Sep 25, 2003 10:26 PM
