if i micropolish the crank do i need different size rods?
Old Jan 19, 2006 | 02:59 PM
error's Avatar
Default if i micropolish the crank do i need different size rods?
spun a bearing and i will most likely have to micro p. the crank. im also getting new pistons and rods..... what determines the correct rod size to buy? im going to be 81.5 on a b18a block eagle rods and srp pistons 8.9:1
Old Jan 19, 2006 | 03:21 PM
2001accord's Avatar
Default Re: if i micropolish the crank do i need different size rods? (error)
What ever block you have detemines the size. If you spun a bearing and the micro polishing can get it out, you will just need larger bearings on that journal. If they can't get it out may need new crank
Old Jan 19, 2006 | 03:38 PM
error's Avatar
Default Re: if i micropolish the crank do i need different size rods? (2001accord)
Old Jan 19, 2006 | 04:31 PM
_BEN_'s Avatar
Earl micropolishes cranks.
Give him a pm and he may be able to tell you more about what needs to be done.
Old Jan 19, 2006 | 07:49 PM
error's Avatar
Default Re: if i micropolish the crank do i need different size rods? (_BEN_)
cool. and hes so cal too right? thanks
Old Jan 19, 2006 | 08:05 PM
_BEN_'s Avatar
Yeah Santa Ana (I think)
Old Jan 19, 2006 | 10:09 PM
EnzoSpeed's Avatar
Micropolishing doesn't work that way. Earl will probably tell you to toss the crank and start over with a fresh one.
Old Jan 20, 2006 | 12:53 PM
trickeng's Avatar
Default Re: if i micropolish the crank do i need different size rods? (EnzoSpeed)
micro polishing only removes a "micro" amount. no need for larger bearings. if you need to get the crank ground then you will need oversized bearings.
micro polishing usually is not enough to repair a journal that had a bearing spin on it.
Old Jan 20, 2006 | 01:35 PM
error's Avatar
Default Re: if i micropolish the crank do i need different size rods? (trickeng)
im no expert but it doesnt look severly damaged. i cant feel any gouges and whatnot. but then agin, maybe its beyond the scope of human senses that may affect the wear of the bearings/rod
Old Jan 20, 2006 | 01:58 PM
_BEN_'s Avatar
Your best bet to get the final word would be to talk to Earl.
He is a really cool guy and will take time to answer your questions.
Old Jan 20, 2006 | 03:43 PM
error's Avatar
most def.... ever since ive been a member in 03(had to reg a new name) ive heard nothing but good things about that guy. will be givin him a call/pm shortley
crxsi1
Sep 27, 2013 11:49 PM
joiv21
Feb 25, 2013 09:42 AM
SHhh__VTEC
Jun 2, 2004 11:19 PM
S13 slide
Dec 2, 2002 05:54 PM
