What Kind/Brand Of Motor Oil To Use?
Old Jan 19, 2006 | 10:07 AM
MilanoRed_EJ8's Avatar
Default What Kind/Brand Of Motor Oil To Use?
Alright, I've been reading up a bit, and I've started to get my know how and parts together to build my turbo kit for ..... my stock d16y8.
I know I'm prob. going to hear, swap, N/A, etc, but I want to turbo my d-series, and make it useable for a daily driver. I have plans to purchase a bubble within the next few months that will be my beast.
Now my question is about my oil. Since I'm going turbo I'm going to need a fresh change of oil and perhaps from my understanding, have to use SYNTHETIC motor oil.
Now, back on topic, first off, what kind of oil (5W30-10W30, etc.), and what brand (Mobil1, Pennzoil, Castrol, etc.) of oil do I or should I use?
How do I switch from a non-synthetic oil, that I'm using now, Castrol GTX 5W-30, on a 116,000 mile engine, to a synthetic oil? Just drain and fill, or do I need to do something else?
Any comments or suggestion welcome.
Thanks.
Old Jan 19, 2006 | 10:11 AM
xomp's Avatar
Default Re: What Kind/Brand Of Motor Oil To Use? (MilanoRed_EJ8)
i went straight to mobil1 5w30 at around 160k miles. doesnt seem to be any problems so far.
Old Jan 19, 2006 | 10:14 AM
x93coupex's Avatar
if you want to go from reagular to synthetic i would drain fill with synthetic rund it for a while then do another synthetic oil change if you want to make sure all the regular oil is out. dont really have to do it but if you want to be sure thats what i would do
Old Jan 19, 2006 | 10:16 AM
x93coupex's Avatar
Default Re: What Kind/Brand Of Motor Oil To Use? (x93coupex)
by the way i use royal purple 10w30 good ****
Old Jan 19, 2006 | 10:18 AM
Redline96LX's Avatar
* B A N N E D *
AMSOIL. Only synthetic to reccomend a 25k mile oil change. Yes, it doesnt start to break down till after 8000 miles.
Noticed a slight difference in Amsoil and Mobil1 synthetic in my car, amsoil made it a bit revvier.
Old Jan 19, 2006 | 10:45 AM
zeroice's Avatar
expensive but good i use the same thing before turbo and now while its turboed.... i also have a d16y8
Old Jan 19, 2006 | 11:32 AM
flood's Avatar
Default Re: What Kind/Brand Of Motor Oil To Use? (zeroice)
I wouldn't worry. Your choice of oil won't affect the short life you will have introduced to your stock motor with a turbo.
If you are goign forged internals thats another story. Use synth because of its higher resistance to heat breakdown/sludge in turbo.
bmoua's Avatar
i use 10w30 Castrol for my Y8...runs good...
Old Jan 19, 2006 | 11:43 AM
Chin0280's Avatar
Default Re: (bmoua)
mobil 1
Old Jan 19, 2006 | 12:08 PM
Civichatch2k's Avatar
I have noticed on my own motor that I have a little oil consumption.
I have used the 'honda' brand oil - happened.
I have used Mobil 1 - currently using because could find what I like- still has consumption.
I like Quaker State 5 w 30. I still had consumption just did not seem to be as drastic as with Mobil1 5 w 30 and honda oil.
This statement however, is in no way stating that one motor oil is better then the other, I have now way to prove and dont care to. I just like Quaker State the best.
Just run a synthetic 5w 30 would be good in my opinion. BTW I am all motor not boost.
Old Jan 19, 2006 | 12:12 PM
vc's Avatar
vc
Default Re: What Kind/Brand Of Motor Oil To Use? (Civichatch2k)
mobil1 10w-30 syntethic.
Old Feb 24, 2006 | 11:24 AM
wwang924's Avatar
Default Re: What Kind/Brand Of Motor Oil To Use? (vc)
sorry but i need to jack this thread really quick for ONE question. I think i got faked out, someone just confirm, correct etc. me really quick. Mobil1 full synthetic motor oil is for 5000K? and Mobil1 Full synthetic extended life is the 15K change? I put it in my gf's car, so its under normal driving conditions, I got the mobil1 extended life oil filter. What to do now?
Old Feb 24, 2006 | 11:37 AM
aquarius's Avatar
Default Re: What Kind/Brand Of Motor Oil To Use? (wwang924)
Mobile1 5/30 on my b16a2
Old Feb 24, 2006 | 12:50 PM
wwang924's Avatar
Default Re: What Kind/Brand Of Motor Oil To Use? (AirwaveSi)
thats not what i was looking for....
Old Feb 24, 2006 | 03:18 PM
tl hatch's Avatar
IMHO, just because the oil says 15K miles, you shouldn't wait that long. The oil system in these engines is just over 4 quarts, the filter can only filter so much crap until it needs to be changed.
Unless you have a BMW or Porsche with a 14qt. oil system, I wouldn't go more than 5K in any case.
My .02
Old Feb 24, 2006 | 06:52 PM
nello a.'s Avatar
beware of oil experts carrying flame throwers riding big white horses standing on pedestals
Old Feb 25, 2006 | 04:50 PM
turboek99's Avatar
Default Re: (nello a.)
mobile 1
Old Feb 25, 2006 | 06:03 PM
TurboLaxx's Avatar
Castrol GTX
Old Feb 25, 2006 | 08:21 PM
civicliveit's Avatar
Default Re: (TurboLaxx)
i used mobil 1 15w/50 in my turbo b16a2 and i changed oil every 3k. It get expensive but well worth it in my opinion. I took my valve cover off and the bottom is clean, my buddy who used reg oil in his took his off and he had a bunch of buildup on his valve cover.
Old Feb 26, 2006 | 07:39 AM
GreedyPT's Avatar
Castrol TWS 10W60
Old Feb 26, 2006 | 07:46 AM
00sib16's Avatar
Mobil 1 5 w30 senthytic
Old Feb 26, 2006 | 07:54 AM
jdmjaser's Avatar
Default Re: (00sib16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x93coupex &raquo;</TD></TR><TR><TD CLASS="quote">by the way i use royal purple 10w30 good ****</TD></TR></TABLE>
i use the same
blacksizzle
Jul 6, 2011 03:04 AM
CodyGt3076r
Jan 4, 2011 08:36 AM
Under_Pressure
Apr 27, 2005 01:41 PM
crxhybrid1320
Feb 7, 2003 05:22 PM
StinkyTofu
Apr 9, 2002 10:47 PM
