Oil leaking from back of motor
Old Jan 19, 2006 | 07:32 AM
jspecjoe's Avatar
Default Oil leaking from back of motor
I have oil coming down the back of the block seems to be originating from the pcv valve box , this is a leak no just a drop or two. Do the seals go bad on this black box and cause a a trickle of oil to run down the block? If I can crawl under there i will post a photo
Old Jan 19, 2006 | 07:39 AM
BlueR's Avatar
Default Re: Oil leaking from back of motor (jspecjoe)
yes the seals can go bad...over time, the rubber hardens to the point that is no longer pliable
i had your exact situation happen to me...i just replaced everything
Old Jan 19, 2006 | 07:50 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Oil leaking from back of motor (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">yes the seals can go bad...over time, the rubber hardens to the point that is no longer pliable
i had your exact situation happen to me...i just replaced everything</TD></TR></TABLE>
x2
The seal is a couple bucks at acura. You have to take the IM bracket off but other than that its not that bad. I left my bracket off....
Old Jan 19, 2006 | 09:24 AM
Erik95LS's Avatar
Default Re: Oil leaking from back of motor (walker111)
Are you guys talking about this one? Excuse the craptacular picture.
Old Jan 19, 2006 | 10:06 AM
cool guy name
Default Re: Oil leaking from back of motor (Erik95LS)
Si Senor
Old Jan 19, 2006 | 10:09 AM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Si Senor</TD></TR></TABLE>
Old Jan 19, 2006 | 11:06 AM
jspecjoe's Avatar
I cant imagine getting a quicker better responce. Thanks for the info ......I will rebuild and the itr will be stonger. because of your help......
Old Jan 19, 2006 | 11:38 AM
cool guy name
Default Re: (jspecjoe)
no prob. And throw that PITA IM bracket away after you take it off!!!
HomeDepotMade
Sep 26, 2008 09:13 AM
avotegra
Sep 4, 2008 09:43 AM
top
Mar 19, 2007 01:31 AM
88crxhfb16
Nov 21, 2005 09:37 AM
1.8T_EG
Jul 30, 2004 07:31 AM
