ITB's + mugen cai = ...?
Old Jan 18, 2006 | 11:52 PM
ITSUKA's Avatar
Default ITB's + mugen cai = ...?
just curious on people's opinion
i am currently using a mugen CAI and i was considering purchasing some
EFI(electronic fuel injection) custom made ITB(individual throttle body)
but at the same time have a custom made intake manifold to connect the ITB's to the arm that connects to the mugen CAI
i was thinking that one, since it is EFI it can be tuned for daily driving, and when on track i would simply remove the filter in the CAI and i would have ITB's that suck in colder air from the fender.
just wondering what you guys think of this set up? would there be insufficent air since the space inside the intake manifold would be to small, for the ITB's to work productively? and also would there still be a significant difference in throttle response
with this setup?
i was considering 50mm ID throttle body. currently stock internals but planning on the toda b setup in the near future.
thx in advance!
Old Jan 19, 2006 | 08:25 AM
iperez's Avatar
A CAI with ITBs ?? Is that even possible ??
Old Jan 19, 2006 | 08:27 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (iperez)
I dont think it would be beneficial. But then again I dont know squat about ITB's
Old Jan 19, 2006 | 09:00 AM
hype r 555's Avatar
Default Re: (walker111)
there is a box for the jenvey setup ... i belive it's on jhpusa.com that actually fits on to your itb's so that you can utilize a coventional intake , however i had itb's and my car for a while and after they were tuned .... the car ran awesome ... i simply purchased itb filters off ebay and the car made great power and was very streetable ... !!!
Old Jan 19, 2006 | 09:03 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">A CAI with ITBs ?? Is that even possible ?? </TD></TR></TABLE>
Possible? yes. bennificial? worked well for Tony the Tiger. I can't find any pictures of his old setup though
Old Jan 19, 2006 | 09:05 AM
hype r 555's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it would be beneficial. But then again I dont know squat about ITB's </TD></TR></TABLE>
i don't think that it will make enough of a difference to worry about , obviously you want to filter the itb's but as prev. stated there are ways to do that without having to worry about your cai ... also your itb';s are going to increase your intake charge (cfm) more than you can imagine .... i would leave them uncovered (exept for the small filters ) imo!
Old Jan 19, 2006 | 09:41 AM
AssPenny's Avatar
Default Re: (hype r 555)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hype r 555 &raquo;</TD></TR><TR><TD CLASS="quote">there is a box for the jenvey setup ... i belive it's on jhpusa.com </TD></TR></TABLE>
Really??? Sweet where is it? I can't find it on jhpusa.com
Not meaning to hi-jack the thread, but Hype R 555, what kind of filters did you buy? Foam ones, paper or were they the wire ones like some people run on their turblows?
Old Jan 19, 2006 | 09:44 AM
Erik95LS's Avatar
Default Re: (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Not meaning to hi-jack the thread, but Hype R 555, what kind of filters did you buy? Foam ones, paper or were they the wire ones like some people run on their turblows?</TD></TR></TABLE>
I've heard nothing but great reviews about the ITG filters
Old Jan 19, 2006 | 09:51 AM
AssPenny's Avatar
Default Re: (Erik95LS)
Back on topic: https://honda-tech.com/zerothread?id=1394232
Kind of hard to see in that picture, but there are itb's under that. I think the biggest problem would be in allowing the intake mani to flow more then the ITB's combined (at max). You would have to make the opening huge along with a huge filter I would think.
Then again, I am new to this also, so i could be totaly wrong
Old Jan 19, 2006 | 09:53 AM
Erik95LS's Avatar
well craig just go pop the hood on your M3 and design something similar to that
Old Jan 19, 2006 | 09:55 AM
Dave_B's Avatar
Craig, could you feasably, and I don't know chit about ITB's either but judging by that pic, could you "charge" that chamber with some sort of freon to drastically reduce intake temps? Just a thought.
Old Jan 19, 2006 | 10:01 AM
AssPenny's Avatar
Also, I was thinking the other day that you could make a scoop under the bottom of the car behind/below the engine that would pick up cold air pass it up the back of the engine. Then it could exit out the back of the hood (you would have to do spacers to lift the back of the hood an inch or so). And yes the scoop on the bottom would have to go around the header to avoid heat absorption.
This still doesn't answer the question of filtering, but atleast you've got some cool air.
Old Jan 19, 2006 | 10:03 AM
cool guy name
Default Re: (Dave_B)
I think enclosing the ITB's in something would totally go against its purpose. Like Craig said the intake would have to be huge and also a very non restrictive filter.
Old Jan 19, 2006 | 10:04 AM
AssPenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">well craig just go pop the hood on your M3 and design something similar to that </TD></TR></TABLE>
That is how its done. Cept they have a mass air flow sensor on the intake mani, but it does start with a big filter, then breaks up into individual runners then into the itbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Craig, could you feasably, and I don't know chit about ITB's either but judging by that pic, could you "charge" that chamber with some sort of freon to drastically reduce intake temps? Just a thought.</TD></TR></TABLE>
Yes you could do something like that. Say make the chamber double walled and fill the space between with some kind of liquid coolant. Or you could even draw the air in over a set of vents with liquid coolant in them, kind of like a reverse intercooler.
Old Jan 19, 2006 | 10:07 AM
AssPenny's Avatar
The next step is to take that chamber and put a charge pipe on it like thouse turblow hayabusa guys do
Old Jan 19, 2006 | 10:12 AM
AssPenny's Avatar
Thanks to BlueR
Old Jan 19, 2006 | 10:18 AM
Dave_B's Avatar
Yes you could do something like that. Say make the chamber double walled and fill the space between with some kind of liquid coolant. Or you could even draw the air in over a set of vents with liquid coolant in them, kind of like a reverse intercooler.</TD></TR></TABLE>
Now there's an idea. Hrm. I wonder if someone could fab that up?
Old Jan 19, 2006 | 10:42 AM
hype r 555's Avatar
i used the foam filters for a motorcycle mikuni carb setup !
Old Jan 19, 2006 | 10:58 AM
nafreak's Avatar
Or use one of those FMIC sprayers that shoot the NO2 or CO2 and have it shoot directly on the chamber....
Old Jan 19, 2006 | 11:08 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hype r 555 &raquo;</TD></TR><TR><TD CLASS="quote">there is a box for the jenvey setup ... i belive it's on jhpusa.com that actually fits on to your itb's </TD></TR></TABLE>
How much boost will that box hold?
Nah, nevermind...
Old Jan 19, 2006 | 11:43 AM
Erik95LS's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">How much boost will that box hold?
Nah, nevermind...</TD></TR></TABLE>
do eet!
I think Tony the Tiger's Plennum is a good design and might even be large enough, but I'd like to see a much larger intake pipe (maybe 3-4 inchs) on it, possibly running to a very large filter. NSX Mugen Airbox anyone?
Old Jan 19, 2006 | 02:01 PM
Black R's Avatar
25 Year Member
Default Re: ITB's + mugen cai = ...? (ITSUKA)
just get the itb's on there before you start pondering all the vaporware....
then when you are ready:
Old Jan 19, 2006 | 02:08 PM
AssPenny's Avatar
Default Re: ITB's + mugen cai = ...? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">just get the itb's on there before you start pondering all the vaporware....</TD></TR></TABLE>
Old Jan 19, 2006 | 02:24 PM
charlie powerhouse's Avatar
sell the mugen intake to me.
Old Jan 19, 2006 | 02:26 PM
Bradstard's Avatar
It holds 12psi in this video...on 11.5:1 compression too
https://honda-tech.com/zerothread?id=1027496
