rear motor mount bracket question
Old Jan 18, 2006 | 07:53 PM
hybridpatient95's Avatar
Default rear motor mount bracket question
any one if the accord and h22 rear motor mount brackets are the same or is one longer than the other? because my rear motor mount bracket doesnt seem to reach my mount its missin bout a half an inch to an inch.. this is going into a eg with hcp mounts
Old Jan 19, 2006 | 02:55 AM
Default Re: rear motor mount bracket question (hybridpatient95)
bump!
Old Jan 19, 2006 | 12:11 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridpatient95 &raquo;</TD></TR><TR><TD CLASS="quote">any one if the accord and h22 rear motor mount brackets are the same or is one longer than the other? because my rear motor mount bracket doesnt seem to reach my mount its missin bout a half an inch to an inch.. this is going into a eg with hcp mounts </TD></TR></TABLE>
liek i said to you before your going to need the h22 rear mount. the accord one is shorter.. and if you try to use that you going to tip your motor WAY back. look on http://www.slhondaparts.com i know the part numbers are different. you need to match the mounts to the motor.
Old Jan 19, 2006 | 12:28 PM
yea i know that.. its just that i bought this mount cause i parted together this motor together.... now i dont know why its not working with it
Bob_760
Sep 7, 2006 08:50 PM
boostin4door
May 23, 2005 04:41 AM
C M S
Dec 14, 2004 08:11 AM
InjectedPerformance
Oct 8, 2004 12:45 PM
k_spek
Jul 22, 2004 12:01 PM
