JDM GSR and Type R speed govner
JDM Type R instrument cluster reads 180 km/h witch is like 110 or so? are they limited to 110 or can they go faster? or would you need a USDM gsr or type r ecu ?
If you put a JDM cluster in a US car then no it wont have a speed limiter. The speed limiter is controlled by the JDM ECUs only, not the cluster.
so are the jdm ecu's limited to 180 km/h? I have a jdm B18c on the way. and wanted to know if it was limited? thanks for the help!
will a USDM gsr ecu work well on a jdm gsr swap? or would it be better to chip the jdm ecu? I don't want the moter to have less performance with the usdm ecu, or does it make a diffrence!!! thanks-a-bunch !!!!!!!!!!!!!!!!!!!!!!!
You won't hit the speed limiter on public roads or on most racetracks.
If you're planning to run on a road course with an especially long straight, then look into removing the limiter.
Until then, don't worry about it. I've been driving around with a speed limiter for months, including two track days without a problem.
but I sure do like to go fast!! I have had my 94 ls to 140 on the roads around town!! I realy just want to know that my car can do what it is able to do not held back, ,, so it would not be a good idea to use the usdm ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve-o »</TD></TR><TR><TD CLASS="quote">but I sure do like to go fast!! I have had my 94 ls to 140 on the roads around town!! I realy just want to know that my car can do what it is able to do not held back, ,, so it would not be a good idea to use the usdm ecu?</TD></TR></TABLE>
140mph on city roads? Idiotic if you ask me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve-o »</TD></TR><TR><TD CLASS="quote"> I have had my 94 ls to 140 on the roads around town!!</TD></TR></TABLE>
