LS/VTEC bolts/studs NEED HELP
Old Jan 18, 2006 | 07:15 PM
mountaindewguy's Avatar
Default LS/VTEC bolts/studs NEED HELP
Do i really need to upgrade the rod bolts on a simple LSVTEC? it will not be a built engine, just the standard swap with a few bolt ons (I/H/E) stage 1 clutch/flywheel and MAYBE mild cams.... nothing extreme..
also, do i need the ARP studs? or head bolts? or will the GSR studs/bolts work???
thanks!
p.s. im using the GSR head.
Old Jan 19, 2006 | 11:15 PM
Default Re: LS/VTEC bolts/studs NEED HELP (mountaindewguy)
up.
Old Jan 20, 2006 | 01:32 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
If your building the motor, why not just upgrade the rod bolts anyway?
I would use ARP head bolts, for a B18 block, or whatever block you are using.
Old Jan 20, 2006 | 01:22 PM
Default Re: LS/VTEC bolts/studs NEED HELP (JDM_Ej)
thats just it, i mean, im building the lsvtec, but its pretty much gonna be stock everything, only aftermarket there will be will be mild stuff (intake, exhaust, header, clutch, etc)
is it worth it? i mean, am i in danger with throwing a rod with that mild setup?
akura404
Mar 3, 2006 02:12 PM
92CiviC4dr
Jan 26, 2006 06:50 PM
D.Dappa
Mar 11, 2005 07:53 PM
KillaB-
Sep 19, 2004 11:49 AM
riceball777
Oct 22, 2003 07:56 PM
