My car revs up when idle
Old Jan 18, 2006 | 05:32 PM
aguilasrafa10's Avatar
Default My car bounces up and down on idle when stepping on accelerator when warm
I have a 1994 Honda Civic Ex and its giving me problems. I already took it to 4 mechanics and no one seems to know whats wrong. I was wondering if someone could help me find the problem. The car revs up and down when it gets warm on idle. It does it when you step on the accelarator. It bounces up and down for about 10 seconds and then goes back to normal. I've notice that this happens when the fan turns on. This problem makes it hard to drive because it stalls when it does this. Can anyone help me?
Modified by aguilasrafa10 at 7:31 PM 1/19/2006
Modified by aguilasrafa10 at 7:32 PM 1/19/2006
Old Jan 18, 2006 | 05:36 PM
Cute EK's Avatar
Default Re: My car revs up when idle (aguilasrafa10)
tps?
Old Jan 18, 2006 | 05:42 PM
x93coupex's Avatar
Default Re: My car revs up when idle (Cute EK)
^^^ yeah i would start at the tps first then maybe the IAC
Old Jan 18, 2006 | 09:02 PM
Hollywood...'s Avatar
Default Re: My car revs up when idle (x93coupex)
I had a vacuum leak and that happened too. Check that.
Old Jan 18, 2006 | 10:49 PM
AnDThEnWuT's Avatar
Default Re: My car revs up when idle (Hollywood...)
fitv (fast idle therm valve) maybe?
Old Jan 19, 2006 | 06:01 PM
slimisred's Avatar
definately the TPS or a vacuum leak to the intake manifold
Old Jan 19, 2006 | 06:44 PM
Default Re: (slimisred)
i changed the tps already and it still does the same thing. once the engine gets warm it starts doing it. it does it for about 10 seconds and then it stops.
Old Jan 19, 2006 | 06:55 PM
Cute EK's Avatar
Default Re: (aguilasrafa10)
Changed the tps? How did you manage that?
Old Jan 19, 2006 | 07:10 PM
Default Re: (Cute EK)
the tps is attached to the throttle body. had to change the whole throttle body but it continued to do the same thing. you have any idea of what it might be?
Old Jan 19, 2006 | 07:17 PM
Cute EK's Avatar
I thought you meant, actually changing just the tps. Hmm...try checking the pcv?
Old Jan 19, 2006 | 07:23 PM
RTI's Avatar
RTI
is your cel on?
Old Jan 19, 2006 | 07:26 PM
Default Re: (RTI)
what do you mean?
Cute EK's Avatar
cel=check engine light
Old Jan 19, 2006 | 07:37 PM
no. i dont know if its a sensor or a vacuum leak.
Modified by aguilasrafa10 at 9:01 PM 1/19/2006
Old Jan 19, 2006 | 07:40 PM
Cute EK's Avatar
It sounds like a vacuum leak, try listening for a hissing sound while the engine is running.
Old Jan 19, 2006 | 07:58 PM
hondagriz
Guest
Posts: n/a
definitely a vacuum leak.. or you have a bad idle air control valve.
Old Jan 19, 2006 | 08:06 PM
Sir_Wallace's Avatar
Default Re: (hondagriz)
Did you try adjusting your idle speed. Honda's have idle problems in cold weather when an after market intake is added. And if you had a vacume leak your RPM's would drop at 4k when you speed up.
followthadollar
Apr 20, 2010 06:23 PM
b16crx88
Mar 19, 2005 11:14 AM
kihun_cha
20
Sep 17, 2004 03:18 PM
diLUDEd
Aug 22, 2002 10:08 PM
