VTEC wiring and Map sensor problems!?
Old Jan 18, 2006 | 12:31 PM
G2TegGuy's Avatar
Default VTEC wiring and Map sensor problems!?
I went to the dyno yesterday to see what kind of numbers I was running. Well i was running slightly lean up until vtec hit and extremly lean while in vtec. They upped to fuel press to 50PSI. Same thing happened. Previously I had been throwing a map sensor,knock sensor, and Eld code. They wired the knock sensor,good. Also the ground wire for the Vtec sole. was not grounded. They grounded that. Im guessing that I need to trouble shoot the map sensor. Also apon leaving the dyno my car would bog terribly taking off from stoplight unless I took off from 2500 or above. I had this problem once before so I unhooked the ground wire from the solenoid and no bogs, no crazy idle either. I have a 92 ls with 95 gsr swap w/ VAFC as tuning method. Any help would be great as to why a grounded vtec sole. wire would cause car to bog?? Ive heard or cars running rich with a bad Map Sensor but would it cause it to run lean??
Old Jan 18, 2006 | 01:55 PM
G2TegGuy's Avatar
Default Re: VTEC wiring and Map sensor problems!? (G2TegGuy)
Anyone??
Old Jan 19, 2006 | 08:24 AM
G2TegGuy's Avatar
Chime in with some knowledge..
EK9ED
10
Oct 26, 2009 04:43 PM
crush
Jul 18, 2005 12:59 PM
lysergican
Jul 12, 2002 04:29 AM
GTEater
Aug 23, 2001 06:23 PM
