Dome light doesn't come on when I open my door.
Does anyone know what is up with this? No matter what position the swich is in (the center one is where it should be for this to happen), my dome light will not come one when I open driver or passeger door. It's a 97 LX four door, btw.
Check the door switch. Take it out and short the wire to ground. If the dome light, in the center position, does not light either the bulb or the switch at the light is bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden »</TD></TR><TR><TD CLASS="quote">you need to do some rewiring if you have an aftermarket head unit. its just jumping 2 wires together.</TD></TR></TABLE>
thats is what was wrong with mine. i had to connect 2 wires behind the radio on my old 98 ex to make the dome light come on with my doors.
He said that the lights don't come on even when he manually tries switching them on. If he had an aftermarket radio, the lights will still come on if he turned the interior switch to "on." At least mine do.
-Shane
-Shane
by the way the dome light in my wifeys civic wouldnt work in any position either. I had to take the screws out of the back of the switch and take a small piece of sandpaper and clean the contacts. put it back together and into the car , worked like a champ.
John Anderson
13
Mar 30, 2012 06:44 PM
