hmm?? my pulley just fell off when i was drivin.? why?
Old Mar 21, 2002 | 03:36 PM
civicracer1993's Avatar
Default hmm?? my pulley just fell off when i was drivin.? why?
well i was drivin and i hear a noise and my pulley for the alternator and AC is laying in the street/?? i found it and teh 2 belts but not the bolt to hold it in.. luckily a friend has one i can use but why would this just fall off?? if that came off is there anything else i should check to make sure nothin else happens??
its a 89 civic HB
mike
Old Mar 21, 2002 | 03:48 PM
virginia_dude's Avatar
Default Re: hmm?? my pulley just fell off when i was drivin.? why? (civicracer89)
Maybe a ghost is playing games with you? Stange, seriously I have no idea, thats weird. BOTH of them?
Old Mar 21, 2002 | 04:12 PM
MilanoRex's Avatar
Default Re: hmm?? my pulley just fell off when i was drivin.? why? (virginia_dude)
the only thing i can think of is if your ride is very bumpy, the screws could have come loose over time.
Old Mar 21, 2002 | 05:28 PM
i dunno.. the ride is a lil bumpy thanks to cut springs but still it shouldnt of come off.. no just one pulley. the alt and AC one... also which way takes the big bolt out? is it left like a normal screw or is it to the right ??
thanks
mike
Old Mar 21, 2002 | 05:39 PM
AfEn808's Avatar
New User
did you change your pulleys and just not tighten them well or what and yeah its left to take nut off.
Old Mar 21, 2002 | 08:02 PM
Cryptopsy's Avatar
Man, pulleys falling off...sick!
Old Mar 22, 2002 | 04:12 AM
They are all Right hand thread. Nothing out of the normal. The main crank pulley should be a bear to get off, It has some serious tourqe on it. The others, I haven't even figured out how to get off.
Old Mar 22, 2002 | 06:36 AM
Trinity's Avatar
when u hit 6000 rpms a little gremlin hops out your radiator and starts pulling bolts
maybe that was the cause of it.........where you making a sharp right turn? that would have sent him flying to that side of the engine. Your lucky it wasn't your crank pully.
Old Mar 22, 2002 | 06:42 AM
WuShu's Avatar
New User
Default Re: hmm?? my pulley just fell off when i was drivin.? why? (Trinity)
Old Mar 22, 2002 | 07:13 AM
SiR Kid's Avatar
New User
Default Re: hmm?? my pulley just fell off when i was drivin.? why? (HondaCRX)
ROFL @ HondaCRX
Old Mar 22, 2002 | 09:37 AM
4g4me's Avatar
Wait your pulley fell off!? Oh **** that means that your r/s ratio is off! The only way to fix it is to buy a new crank and use the alternator bracket off of an 88 wagovan civic. Could be vaccum lines though. But remember, the only thing that really goes bad on hondas is the distributor, so that means that your valves are worn. You could always go the cheap route and wire in an RPM activated switch to your fuel pump relay, cutting off your fuel at 3850rpm. I had to do that once, but it involved pulling the motor, I wouldn't do it again.
Old Mar 22, 2002 | 10:04 AM
SiR Kid's Avatar
New User
Default Re: hmm?? my pulley just fell off when i was drivin.? why? (4g4me)
BUAhahahahahahahahahahahahahaha!!!!
THUMP!
<Proceeds to pick himself up out of the floor, dust himself off, and clicks to go back to the ef/crx forum>
Old Mar 22, 2002 | 11:55 AM
Default Re: hmm?? my pulley just fell off when i was drivin.? why? (SiR Kid)
hmmm??? well whatever but anyway i fixed it today.. it better not come off again..
mike
Old Mar 22, 2002 | 12:08 PM
CRX7's Avatar
Just bolt it on harder this time and use some threadlock if you're really worried about it.
hotdoggies
13
May 16, 2020 02:28 PM
acmoc
11
Apr 29, 2009 11:59 AM
Ritchie
May 17, 2007 11:10 AM
David G
Sep 28, 2002 12:25 PM
CKim
Mar 4, 2002 05:40 AM
