Honda S2000 Honda S2000
Air Ratio
Old Jan 18, 2006 | 08:38 AM
spooniq's Avatar
Default Air Ratio
Im running on 7-9 psi turbo. My air fuel ratio is at 12.8. I meet some guys that r running 11.5 and said my car is running lean. What air fuel ratio should I be running to be safe?
Old Jan 18, 2006 | 09:14 AM
devnull's Avatar
Depends on the engine. Best way to find out is tuning. Turbo though is typically 11.5-12.3
Old Jan 18, 2006 | 01:38 PM
Mase's Avatar
Default Re: (badboypolar2)
you want to be 11.8-12.0:1 under full load.
Old Jan 18, 2006 | 04:21 PM
revhi's Avatar
Agreed, I was at 11:1, to rich. Right around 12 is ideal.
Old Jan 19, 2006 | 07:26 AM
spooniq's Avatar
Default Re: (revhi)
So am i running lean? Should I drop it lower? how about 12.5? Or lower? I heard you loose power if its too low.
Old Jan 19, 2006 | 09:15 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (spooniq)
If you don't know for sure, throw your car on a dyno and have a competent tuner set your A/F ratio.
Old Jan 20, 2006 | 08:49 AM
spooniq's Avatar
Default Re: (Slideways2000)
Thants what i did. They tuned it to 12.8. And he said its perfect, but the guys I meet at the streets said im running lean. it should be like 12.0
Old Jan 20, 2006 | 09:15 AM
* B A N N E D *
Changing it from 12.8 to 12.0 is a bit much. 12.5 is a good starting point, use an EGT also to help determine if it's lean or rich.
91preyludesi
Sep 4, 2005 09:33 AM
SpoonFedHatch
Feb 24, 2004 05:59 PM
ddua
Oct 4, 2003 10:08 AM
ELSpool
May 9, 2003 02:06 AM
DOHCTOR
Apr 21, 2002 04:36 PM
