LS integra DOHC 16V at junkyard any useful parts?
There is a 89 Integra LS at my junkyard it has a DOHC 16v engine. Is anything useful here to use on a 89 CRX Si?? Can the top part bolt to a CRX's bottom??? ECU or injectors do anything??? Thanks guys?
If anyone needs anything off this car I will pull it for you and ship it.
What motor is in that car? Motor an good? Ill find out prices on that stuff. Where is the ECU located? TBody there
I've also read that you can use the pistons to yield higher compression.
Check this out. https://honda-tech.com/zerothread?id=141776
Ill get prices today sometime. Pistons prolly 20 cdn. ECU 15 cdn tbody 15 cdn intake manifod 17 cdn These are not exact around that price range. I need to make somthing on the hard to take out parts like pistons ill charge 5 cdn to take them out.
89 crx si you were out to pick a part were you well the ecu is gone and i have some of the wireing for my zc swap and the inner shaft off it the rest you can have
Well, since every one is on the subject. A junk yard near me has three Integras Dohc 16v non vtecs.Two 1986's and a 1988. It's a pick and pull I just go in, get what I want, and they quote me a price. Mom and POP type junk yard, out in the sticks.
Can I use the ECU from the 88 Teg?
Later-HC4G
Later-HC4G
Theres a CRX at my yard that hit a pole! It had a header but was badly crushed. I took the heder off and cut the pipes so now i only have the flange with 4 holes. I then took it to a machinist and he is going to make me a turbo manifold from holley mendrel bent header piping!! now i got my turbo manifold for 40 cdn and turbo off 300ZX for 47 cdn. turbo tubes are 30 cdn mendrel Almost all i need
4DRmafia
Aug 17, 2004 05:46 PM
hybrid1990crx
Aug 17, 2004 11:31 AM
mateencrx91
Nov 20, 2003 11:32 AM
and a turbo off a 300ZX
