88-89 or 90-91 light ?
Old Mar 21, 2002 | 03:30 PM
tunedcivic's Avatar
Default 88-89 or 90-91 light ?
wtf is the difference...i cant find projectors for my 89
Old Mar 21, 2002 | 05:38 PM
markedOO1's Avatar
Default Re: 88-89 or 90-91 light ? (tunedcivic)
..none.
Old Mar 21, 2002 | 05:39 PM
Truffle Shuffle's Avatar
Default Re: 88-89 or 90-91 light ? (marked001)
Taillights are diff... but the headlights arent.
Old Mar 21, 2002 | 06:18 PM
StorminMatt's Avatar
Default Re: 88-89 or 90-91 light ? (RaceInspired)
The later headlights are different to accommodate the different corner markers used on later cars.
Old Mar 21, 2002 | 06:44 PM
tunedcivic's Avatar
Default Re: 88-89 or 90-91 light ? (StorminMatt)
so can i use 90-91 lights?
Old Mar 21, 2002 | 08:51 PM
superslowhatch's Avatar
The only different is the headlamp housing and if u use 90-91 headlamp, u have to use 90-91 side marker. 88-89 side marker have 2 screws on the side of the fender instead 90-91 have 1 screw into the headlamp housing . There's a little different. So careful !
Old Mar 21, 2002 | 11:02 PM
CRX-RX's Avatar
Default Re: 88-89 or 90-91 light ? (superslowhatch)
The only difference is a bracket attached to the housing for the corner lamps. The actual headlight housing is the same, you will just need to swap the bracket for the corner lamps. Good luck getting those screws out though, they usually rust in there, so plan on buying a new set from honda, cutting them off, or upgrading to 90-1 corner lamps.
Old Mar 22, 2002 | 01:38 PM
tunedcivic's Avatar
Default Re: 88-89 or 90-91 light ? (CRX-RX)
i wsnt 90-91 lights...so now for this ?. what is the best place to get nice projectos from??
anj_jmv
21
Oct 20, 2007 04:47 PM
fuhrermatt
Sep 2, 2006 10:07 AM
pinecone
May 1, 2006 10:51 AM
steronz
Sep 18, 2004 07:48 AM
CrX-To-Tha-Max
10
Mar 6, 2004 06:04 PM
