GSR VALVETRAIN IN B16 HEAD
my friends got his complete valvetrain from his gsr i was wondering what i would be looking at if putting in my head is it gunna be worth my time or just trouble?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRIJPURT13B »</TD></TR><TR><TD CLASS="quote">DA GSR CAMS R BETER DEN DA B16 CAMS..DATS ABOWT IT,,PUTING DA RETS OF DA VALVE--TRANE WUD BEE WAIAST UV TIME..WELL MAYBEE DA LOST MOSHIN ASSEMBBLYS ARE STRONGER DEN DA B16 1'S..I NO FOR A FAC DAT DA 1ST GEN B16 HEDS HAV DA WURST UV DA B-SERIES CAMS</TD></TR></TABLE>
It's you again.
It's you again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si »</TD></TR><TR><TD CLASS="quote">
It's you again.
once you translate everything you'll see that this guy knows his stuff..
It's you again.
</TD></TR></TABLE>once you translate everything you'll see that this guy knows his stuff..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">
once you translate everything you'll see that this guy knows his stuff..</TD></TR></TABLE>
yes, he does, but damn...kinda annoying
Ill translate it everyone..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRIJPURT13B after english conversion »</TD></TR><TR><TD CLASS="quote">The GSR cams are better then the B16 cams,that's about it.Putting the rest of the valetrain in would be a waste of time,well maybe the lost motion assemblies are stronger then the b16 versions.I know for a fact that the 1st gen b16 heads have the worst of the b-series vtec heads
</TD></TR></TABLE>Ill translate it everyone..
well i already have ctr intake camshaft and itr exhaust camshaft so im not going to be needing cams so the valves and springs and **** wont really matter cause its all about the same then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990 CRX Si »</TD></TR><TR><TD CLASS="quote">well i already have ctr intake camshaft and itr exhaust camshaft so im not going to be needing cams so the valves and springs and **** wont really matter cause its all about the same then?</TD></TR></TABLE>
Exactly.
Exactly.
This has been covered in many many threads....the only head to get duel valve springs on both intake and exhaust valves, is the type r head. It is very easy to add the extra set of springs to the exhaust on a regular pr3 or p72 cylinder head
