Need serious help! ASAP please help!
Old Jan 17, 2006 | 09:08 PM
Pony_Fed95's Avatar
Default Need serious help! ASAP please help!
Ok so here is my situation... I had b20/vtec in my 92 hatch and it dropped a valve. So I pulled the motor and I put in an obd0 LS motor. I got a P75 obd1 ECU for it. And I re-used my GSR wiring harness. I am still using the obdo intake manifold too(but I made some block off plates for vaccum leaks)
My problem is.... Ok I got the motor in with everything hooked up. When i start the car is takes a sec before it actually starts... but when it does start it idles at 3000 rpms. And it kinda sputters a bit. It throws a few codes too.... 4(CKP{in dizzy}), 6(water temp), and 7(TPS). Now the TPS and the water temp I already know about. Timing is perfect and I cant find any vaccum leaks. I got a BRAND NEW dizzy and it throws the same codes.
Now here is where I gave up and decided to ask you guys. We took my buddies OBD1 P72 GSR ecu and plugged it in to my car. The car still idled real high but it didnt throw the Crank pos. Sensor(code 4). The only one it added was code 21 witch is for vtec so that was expected. ALSO, the motor idled high still but it wasnt sputtering anymore.
Now to make it even more confusing we put my P75 ECU into his gsr and it ran perfect! No codes and no problems what-so-ever! Please help ASAP I need this car for school!
Old Jan 17, 2006 | 09:26 PM
Pony_Fed95's Avatar
bump
Old Jan 17, 2006 | 09:49 PM
x_outlaw_x's Avatar
get an obd-1 to obd-0 conversion harness
http://www.boomslang.us has them
Old Jan 17, 2006 | 10:37 PM
Pony_Fed95's Avatar
Default Re: (x_outlaw_x)
What??? How will that fix my problem? Plus they dont make one for OBD1 to OBD0 bro. I just need to know why its doing this. Could it be the wiring harness I am using maybe damaged?
Old Jan 17, 2006 | 10:44 PM
x_outlaw_x's Avatar
did you convert the engine to obd1? if not thats what your problem is...because an obd1 wont run an obd0 engine right, because of the sensors
Old Jan 17, 2006 | 10:45 PM
StopTheShitTalk's Avatar
Default Re: (Pony_Fed95)
Fast Idle Air Control Valve under the throttle body, buy a new one or bypass it
Old Jan 18, 2006 | 08:47 AM
Pony_Fed95's Avatar
Default Re: (StopTheShitTalk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StopTheShitTalk &raquo;</TD></TR><TR><TD CLASS="quote">Fast Idle Air Control Valve under the throttle body, buy a new one or bypass it</TD></TR></TABLE>
You mean the one that is attached to the TB? Or the one that is on the manifold below the TB? If you could give me a pic that would be great.
So you guys think that If I get and OBD1 intake mani that it will run right?
Old Jan 18, 2006 | 08:48 AM
Pony_Fed95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">did you convert the engine to obd1? if not thats what your problem is...because an obd1 wont run an obd0 engine right, because of the sensors</TD></TR></TABLE>
What do you mean convert it? I have an OBD1 dizzy, ecu, wiring harness, TB.
Old Jan 18, 2006 | 09:59 AM
x_outlaw_x's Avatar
yeah you converted it...now get an obd1 intake manifold and it will run great
Old Jan 18, 2006 | 10:03 AM
Pony_Fed95's Avatar
Sweet, I will try that today. The only manifold I can get is a B16 obd1 mani will it fit? I heard they do.
Old Jan 18, 2006 | 10:07 AM
Luserkid's Avatar
I would get the obd1 intake manifold as well. But that CKP problem is weird if your running a obd1 dist. with ecu and harness. I would look at the ecu. Try getting a 3rd ecu and see if the car will throw the code or not.
Old Jan 18, 2006 | 10:09 AM
x_outlaw_x's Avatar
yes, obd1 b16 will fit
Old Jan 18, 2006 | 12:08 PM
Pony_Fed95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">yes, obd1 b16 will fit</TD></TR></TABLE>
Ok good cuz I can get my hands on one of those. I will try to get a 3rd ecu but I can think of anybody else that has one.
lingo104
11
Jan 31, 2011 03:38 PM
paul8ex
May 9, 2008 05:32 PM
Pony_Fed95
Jan 18, 2006 12:06 PM
joek84
Jan 6, 2004 04:14 PM
