need help ASAP
need help ASAP
i did try and search but i couldnt find anything like my prob. i have a 98 civic ex with an ls vtec swap and the bottom end is obd1 so it dosent have a crank sensor. becuz of this it throws a code and i cant get it to pass emisions. is there anything i can do to trick the ecu??? thank you for the help guys....... o ps iam running the ex harness and stock sohc ecu for emisions
Re: need help ASAP (civicjoe)
not trying to be a dick but no you dont. i have run obd2 to pass emisions and the car should have a crank sensor but because its obd1 it dosnt and i need to know if there is a way to a. either trick the ecu with some kinda wire trick or b. but in my own crank sensor ...but thanks anyway
sikcrx80
05-01-2023 05:16 PM
