IAB on a p28
Old Jan 17, 2006 | 02:52 PM
hondabigblock's Avatar
Default IAB on a p28
Search | Go
Author: Deluded Date: 07-24-03 23:44
READ CAREFULLY: The procedure to add IABs is different depending on how they are wired. One IAB wire will always run to the ECU, the other will run to either +12v or gnd. Choose the procedure to match how your car is wired! This is very important!
USDM ODB1 B18C: ( ECU sends ground, IAB wired to +12v )
IAB conversion... (this is for Manual cars only, but an AUTO USDM ECU converted to manual will have all the parts you need present)
Remove: R135...11F0/1720 autos only R150...1980/LS only
Add:
Q17(A143)...already present on USDM auto 11F0/1720 (A5x, L5x, etc). Not present on EDM auto 11F0/1720 (G5x, etc).
Q34(D1780 or C3225?)... already present on USDM auto 11F0/1720 (A5x, L5x, etc). Not present on EDM auto 11F0/1720 (G5x, etc). may use PCS trans: Q31(D1780)
jumper from right hole of R135(trans side) to D13(arrow side)
Jumper wire for OBD1 IAB control:
I am trying to make the iab work with my p28. I have already soldered the jumper wire in from r135 to d13. These directions are just confusing me ? Does anybody know how to do this? Thanks
Old Jan 17, 2006 | 07:47 PM
RMS's Avatar
RMS
i am deluded
email me. include what year the car is that this will be installed in.
ProjectRustyEF
Engine Management and Tuning
18
May 25, 2013 07:44 PM
90AccordVTEC
Oct 12, 2005 11:27 PM
thumbtack
Jul 26, 2004 09:01 AM
stripes777
Mar 29, 2004 11:31 PM
turbotime
Nov 29, 2003 03:53 PM
