cant get it started..... help!!!!
Old Jan 17, 2006 | 02:28 PM
flipstar760's Avatar
Default cant get it started..... help!!!!
i just pickup a 92 cx hb... and i cant get it started.... when i crank it want start. when u just turn it to the ON u dont hear the little whine form the fuel pump.
ok it has a new distr. new starter... what could it be... the ecu or the pump..or what... help me please
Old Jan 17, 2006 | 02:32 PM
x_outlaw_x's Avatar
pull the back seat up and have somone turn it to the on position with your head by the fuel pump cover and see if you hear the fuel pump prime...if it doesnt try your main relay...if it primes check your coil
Old Jan 17, 2006 | 02:42 PM
Default Re: (x_outlaw_x)
which coil...?
Old Jan 17, 2006 | 02:44 PM
x_outlaw_x's Avatar
the ignition coil...the one in the distributor...just trade it out with a friend that has a running car and see if that fixes it
Old Jan 17, 2006 | 04:03 PM
Syndacate's Avatar
can u give more info? Is it turning over? Maybe a frozen fuel line? probably a burnt out fuel pump if u don't hear that humming sound for like .8 of a second
To check if the distributor's working, unplug the spark plugs (and leave them connected and see if there's a spark in all 4 plugs when you turn over the engine (need 2 pple for that)
pmey
May 26, 2009 01:11 PM
zcmotor
30
Mar 17, 2008 05:53 PM
H22TurboNos
Nov 5, 2007 03:16 AM
Combustion Contraption
Jan 7, 2005 10:40 PM
JolToN49
Nov 20, 2002 11:41 AM
