what is wrong with my "new" clutch
Old Jan 17, 2006 | 11:26 AM
sshonda2004's Avatar
Default what is wrong with my "new" clutch
i just had a new clutch installed in my 97 civic, and when and when i get to say third or fourth gear, its seems like my clutch begins to stick even when the clutch isnt engaged, the rpm would redline and the speedometer needles stays at like 40mph like its stuck or somethin, please help, can i fix this myself or what?
Old Jan 17, 2006 | 11:48 AM
snatch's Avatar
Default Re: what is wrong with my "new" clutch (sshonda2004)
So you're in 3rd or 4th gear, step on the gas and the RPM's rise but the speed doesn't? Is that correct?
Sounds like the clutch is slipping. Did you have a shop replace it for you? If so, take it back. Could be they didn't resurface the flywheel, there is oil/grease on the clutch disc. If they did it, they need to fix it.
Old Jan 17, 2006 | 12:00 PM
Everyones Hero's Avatar
Default Re: what is wrong with my "new" clutch (******)
I think he's saying just the opposite. Like if he redlines it, puts in the clutch and tries to coast it doesn't slow down, it keeps the motor loaded.
Did you brake the clutch in correctly?
Old Jan 17, 2006 | 01:24 PM
Default Re: what is wrong with my "new" clutch (Everyones Hero)
aite thanks preciate it
threesixes
Oct 5, 2007 11:42 PM
vietdragontekx
Aug 27, 2005 06:27 PM
FLCivic
15
May 31, 2004 09:22 AM
sazaks
Mar 10, 2003 05:20 AM
LOwrestling2001
May 26, 2002 03:28 AM
