Wanna see a D16Z6 in a 96-00
Re: Wanna see a D16Z6 in a 96-00 (dohcVTECeg2)
the main difference is the valve cover and intake manifold. Otherwise, just about identical from a pic of the engine bay.
Re: (silverboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost »</TD></TR><TR><TD CLASS="quote">i was just wondering if theres any clearance or mount problems</TD></TR></TABLE>
How could there be? The heads share ALL identical dimentions besides the dizzy, the blocks are virtually the same in & out, the manifolds bolt up to either head, the valve covers swap between the two perfectly. The only dimentional difference is the shape of the intake/exhaust manifolds, the valve cover logo, and the dizzy bolt pattern.
And it's only illegal if the athorities give a damn. Around here, all they care about/give tickets for are tint and mufflers. I've never heard of anyone in WI getting their hood popped by a cop.
Re: (silverboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost »</TD></TR><TR><TD CLASS="quote">the right mount(next to the timing belt) is different thats why im askin </TD></TR></TABLE>
Dude.. No. It fits JUST like a y8,ok?
Re: (silverboost)
The harness wil be different because the Z6 is OBD1 and the Y8 is OBD2 so your going to need a conversion harness or convert the car back to OBD1 which is why its illegal to do so. You have to have the same yr motor in the car that it came with or newer, you cant go backwords, nor can you put a truck motor in there either it has to be a car motor.
If you do a search on obd conversions that should answer your questions on the harness, I just woke up otherwise Id help you with it Its pretty simple to do. theres I think maybe 2 or 3 sensors different.
Re: Wanna see a D16Z6 in a 96-00 (silverboost)
If the mounts are differnt you have to use the one from the Y7 then I belive so it will bolt up to the block, hopefully it will mount up to its counterpart on the car otherwise that will have to be switched as well, I belive Im not 100% sure on this.
Re: (silverboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost »</TD></TR><TR><TD CLASS="quote">no its not the same i have the y 7 and the z6 standin next to each other, the mount is different and the harness is different</TD></TR></TABLE>
I wasn't implying that it was the same in terms of mounts and wiring. I was saying the FIT is the same. As in physical demensions and how it sits in the engine compartment. Does that help to clarify my point?
stolen4drteg
10-04-2006 04:59 PM
99lspwr
06-09-2004 11:53 PM
