Header and oil pan
Old Jan 17, 2006 | 10:11 AM
ekim952522000's Avatar
Default Header and oil pan
Do I need to remove the lower part of the header to chagne the oil pan?
Gettin ready to do it tonight just trying to get a idea of what im going to be up against tonight.
Old Jan 17, 2006 | 10:19 AM
Bbasso's Avatar
Default Re: Header and oil pan (ekim952522000)
You still have a stock exhaust manifold?
To be helpfull...
I'll send you an IM.
Modified by Bbasso at 3:07 PM 1/17/2006
Old Jan 17, 2006 | 10:22 AM
Default Re: Header and oil pan (Bbasso)
yup car is all stock
Old Jan 17, 2006 | 10:31 AM
Dave_B's Avatar
For ease of it all, yes take it off, though IIRC you can wiggle it out but be careful of the oil pickup screen. Play it safe though, remove the lower part of the header.
Old Jan 17, 2006 | 10:38 AM
Default Re: (Dave_B)
ok thanks
Old Jan 17, 2006 | 02:49 PM
pitargue's Avatar
Do you have a manual? You'll need the torque specs for all the bolts you'll be taking off. You also need to take off the clutch cover. Don't forget to buy the gaskets (2) that goes from the exhaust manifold to the lower pipe. You can reuse the donut gasket that the cat bolts up to.
FWIW...
Old Jan 17, 2006 | 02:50 PM
migs's Avatar
Default Re: Header and oil pan (pitargue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pitargue &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a manual? You'll need the torque specs for all the bolts you'll be taking off. You also need to take off the clutch cover. Don't forget to buy the gaskets (2) that goes from the exhaust manifold to the lower pipe. You can reuse the donut gasket that the cat bolts up to.
FWIW...</TD></TR></TABLE>
SleeperGSR
Jun 23, 2011 05:08 AM
oprac
11
Aug 5, 2007 09:40 PM
RTW DC2R
Apr 5, 2006 07:51 AM
jacoop86
Mar 15, 2006 01:01 AM
kkim
Oct 19, 2003 08:35 AM
