what is this flange for?
Sorry, I don't know what they are for, but what kind of file do you need to cut a flange?
Would this work?
http://www.eville140.com/Heinlin3tc.dxf
Thanks
Randy
Would this work?
Thanks
Randy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evile140 »</TD></TR><TR><TD CLASS="quote">Sorry, I don't know what they are for, but what kind of file do you need to cut a flange?
Would this work?
Thanks
Randy</TD></TR></TABLE>
hey randy, for some reason when i "save as" it saves the file in a txt format, not dxf. i can read dxf, dwg, iges... among others. if you want you can email it to me.
weirtech@cogeco.ca
Would this work?
Thanks
weirtech@cogeco.ca
Looks likeone port is larger then the others. 3SGET 3rd gen. Japan spec. it's not the same as the U.S. spec 3SGET
http://www.monster-turbo.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech »</TD></TR><TR><TD CLASS="quote">hey randy, for some reason when i "save as" it saves the file in a txt format, not dxf. i can read dxf, dwg, iges... among others. if you want you can email it to me.
weirtech@cogeco.ca</TD></TR></TABLE>
Did you get my email with the file?
Thanks
Randy
Thanks
Randy
Thanks
yes i did randy, do the corners rads on the ports have to be so small? can they be a bit bigger? it would make it much easier to cut them.
Thanks
I will see if I can change it a little bit and send you a new file this evening. How big of a radius on the corners do you need?
Thanks
Randy
Thanks
Randy
