HID Problem
Old Jan 16, 2006 | 08:52 PM
joker4096's Avatar
Default HID Problem
Hi guys, I just got a set of Caddilac Escalade HIDs with balasts. I hook it up to the low beams of my car, and when I turn on the lights, the balast makes a loud continuous beep and the hid starts changing colors. I take it off quickly before anything happens. I think that the bulbs are gonna blow if I leave it on. What could be the problem? By the way, my car is a 99 civic cx. all hid experts please help me out
Modified by joker4096 at 11:02 PM 1/16/2006
Modified by joker4096 at 11:34 PM 1/16/2006
Old Jan 17, 2006 | 08:43 AM
joker4096's Avatar
Default Re: HID Problem (joker4096)
please help I really want to put these in
The bulbs are D1S and are made by phillips and osram
I think they are blown because they change colors within 10 seconds
Modified by joker4096 at 12:56 PM 1/17/2006
Modified by joker4096 at 12:57 PM 1/17/2006
Old Jan 17, 2006 | 09:01 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
you mean the HIDs act like HIDs!????????
They're supposed to do that, chatch. Do some research before you make a purchase next time.
Old Jan 17, 2006 | 09:11 AM
joker4096's Avatar
Default Re: HID Problem (Hatchy-Ownzjo0)
Are they suppose to make a continuous beep and then change to a pinkish color?
Old Jan 17, 2006 | 09:47 AM
joker4096's Avatar
You're right, They charge up to a yellowish color. I thought that they were suppose to be blue. I think they're 4600k i thought it was 6000k.
Oh and should I wire up a fuse to these? If so what amperage?
Old Jan 17, 2006 | 09:58 AM
Rionmann's Avatar
*bump* cause I want to know too...
Old Jan 17, 2006 | 10:44 AM
gftgrill's Avatar
ok. when you hook up the power you have to leave it on for about 30 seconds or so. when they finish warming up the color should have stopped changing and the sound should die down a little bit.
it's normal. you want to set up a relay system so that when you turn on the low beams, the hid pulls it's power straight from the battery.
I have two relays setup with both balasts pulling power directly from the batter with their own dedicated power wire. Both power wires have inline fuses. I believe the fuses are 10 or 15 amps. I'm using the cylinder type of fuses.
Old Jan 18, 2006 | 10:16 AM
joker4096's Avatar
Default Re: (gftgrill)
Yea I see, now its time to finda a good set of projectors to retrofit!
robbys89
Feb 9, 2009 09:44 AM
amb4081
Acura TL, RL & ZDX
May 12, 2006 01:47 PM
Devine
Nov 28, 2005 02:31 PM
Beyond Imagination
Aug 14, 2003 01:13 PM
