turbo h22 problems
Old Jan 16, 2006 | 10:36 AM
yoluder's Avatar
Default turbo h22 problems
i have a 5th gen turbo prelude. it cuts off @ around 6k, feels like a rev limiter or fuel cut. Got 450cc injectors but no aftermarket ignigtion. It only does it after 3 or 4 vtec engagements. then around the 7th, vtec doesn't work at all. also have an APEX VAFC II. any ideas??????
Running around 7-9 psi, denso iridium plugs, VAFC, 450cc dsm injectors, test pipe, and 2.5" piping and muffler, boost gauge, but no oil press gauge, and no wideband.
Modified by yoluder at 9:56 PM 1/16/2006
Old Jan 16, 2006 | 10:41 AM
Hawkze_2.3's Avatar
Default Re: turbo h22 problems (yoluder)
More info needed on the turbo setup...
Old Jan 16, 2006 | 11:57 AM
Chuckles99SH's Avatar
no CEL? might want to clean your vtec screen or check to see if you have proper oil pressure that would make vtec not function proper.
Old Jan 16, 2006 | 12:12 PM
PrecisionH23a's Avatar
What spark plugs are you running and what is the gap?
If the answer is not NGK 3330's (bkr7e or bkr7e-11) gapped to .025-.030 then that is your problem.
Old Jan 16, 2006 | 01:18 PM
dreed2300's Avatar
I had the same problem and found out that it was the map sensor causing car to shut down. I put an aem 3.5 bar sensor on and the car runs great.
Old Jan 16, 2006 | 01:48 PM
Default Re: (dreed2300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreed2300 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem and found out that it was the map sensor causing car to shut down. I put an aem 3.5 bar sensor on and the car runs great.</TD></TR></TABLE>
Adding a 3.5 bar map sensor on his set-up is only going to cause his car not to run at all, unless he has an EMS that works with a map sensor like that (which he doesn't) and decides to retune his whole map.
The only other problem could be a malfunctioning missing link valve or those little bleeder valves that you have inline with your map sensor.
Old Jan 16, 2006 | 06:57 PM
prelittlelude's Avatar
like hawk said we need more info.. how much boost are you running, the afc hack only works for so much boost, and also what plugs are you runing and whats the gap?
Old Jan 16, 2006 | 07:21 PM
yoluder's Avatar
Default Re: turbo h22 problems (prelittlelude)
thanks for responding guys. I'm running around 7-9 psi, denso iridiums, CEL shows some misfire and a rich mixture., and nothin with a map sensor, the VAFC is taking care of that part.
Old Jan 16, 2006 | 08:20 PM
RemerLex11's Avatar
Default Re: turbo h22 problems (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
If the answer is not NGK 3330's (bkr7e or bkr7e-11) gapped to .025-.030 then that is your problem.</TD></TR></TABLE>
wait i thought the gap was .044? but i could be wrong.
Old Jan 16, 2006 | 09:49 PM
ChrisRicketts's Avatar
Default Re: turbo h22 problems (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">
wait i thought the gap was .044? but i could be wrong.</TD></TR></TABLE>
yea, you were right.........about being wrong.
the correct gapping for a turbo application is .028-.030
Old Jan 17, 2006 | 09:01 AM
l2yanE's Avatar
souds like it could be a tunning issue, but it also sounds like a possible boost spike, or issue with the missing link or bleeder valves and its wackin the map out, your gonna end up learning the hard way that a vafc is not the way to tune a turbo setup!!! get real engine management hondata aem ect--
Old Jan 17, 2006 | 08:25 PM
yoluder's Avatar
Default Re: (l2yanE)
with your p28, do you also have your stock intake manifold? doesn't it block off half of the stock manifold. Cuz i have a chipped p28 and OBI conversion. do you think this will help?
Old Jan 17, 2006 | 08:29 PM
Techna600f4i's Avatar
Default Re: (yoluder)
too me it sounds like oil preasure problems, posibly low oil... hows your oil feed line to the turbo, any leakage?
Mr.OB*GYN_Rhett
Oct 5, 2008 10:19 AM
hondick14
Sep 5, 2007 08:11 AM
tcontesh
Apr 23, 2006 09:09 PM
jdmGSR.fo0!
Mar 7, 2005 01:18 PM
4gvtec
Apr 29, 2002 08:50 PM
