Please help! Short shifter question
Old Jan 15, 2006 | 10:21 PM
ChiTownLude's Avatar
Default Please help! Short shifter question
I just recently purchased a short shifter adapter for my 98 and I was wondering how I take apart the center column to get to the shifter? Is it just held in by clips because i don't see any screws?
Old Jan 15, 2006 | 10:30 PM
BB6racer's Avatar
there are 3 screws tucked behind the front seats. you will have to move the seat as far forward as possible, like you're letting out someone from the backseat. then there are 2 towards the front. one is out in the open right under the shifter, and one is behind a pull-off panel by where the obd port is. then do the other side. remove the shift ****, and shimmy the center console upwards. there is a wire harness, for the change holder light, and you will have to unplug that before it can be fully removed. also, be careful with the e-brake handle/seat area, its a tight fit. from there it should be pretty easy to figure out. let us know how you like the adaptor!
Old Jan 16, 2006 | 10:15 AM
Default Re: (BB6racer)
Thanks a lot i appreciate it. I will let you know how everything works out.
07FG2
Honda Civic (2006 - 2015)
17
Jan 27, 2010 05:11 PM
DC5mike
Sep 30, 2007 11:53 AM
lif3tak3n
Dec 2, 2005 08:16 AM
crazyclown
Nov 4, 2005 08:39 PM
RFX
Jan 24, 2002 09:32 PM
