Question...wanna get a JRSC for the 94 RS, what kinda tranny/LSD????
stock trans w/ aftermarket LSD?
ITR trans with oem lsd?
if stock trans, who makes an LSD for it?
can I use an LSD out of a ITR/CTR tranny and use it in my 94 RS trans?
all info would be greatly appriciated. thanks
how good is your trans. you could do a rebuild and add a quaife. the rebuild will pretty costly, but the quaife is under a lifetime warranty. another option is to go OEM ITR trans with either the 4.4 or the JDM's 4.7 that includes LSD. if your lucky enough to find a non grinding one you'll spend about 12-16 for one used. now your paying for the short gearing the LSD (which is not, of course, under warranty). i prefer the JDM 4.7 w/ LSD over the LS trans w/ a quaife. the LS rebuilt with LSD will be more costly, as stated previously, buy after the OEM one gives you can rebuilt that too, vice the quife. your choice.
