what are the stock spring rates for integra type R front and rear?
Old Jan 15, 2006 | 04:30 PM
racekar711's Avatar
Default what are the stock spring rates for integra type R front and rear?
just want to compare to the stock ground control which is 350/280 front/rear
i have 350/430 and the car rides to harsh for daily driving for me on koni yellos
thanks
could find it in the search
acutally i found this
F 246 linear
R 140-246 proggresive
not sure if its accurate?
i was thinking of dropping down to 280 i have a asr rear 22mm brace kit.
would i be able to stiffen up my rear koni to induce lift over steer with the rae 280 though? i just cant take the 430 anymore
Old Jan 15, 2006 | 04:39 PM
1GreyTeg's Avatar
Default Re: what are the stock spring rates for integra type R front and rear? (racekar711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar711 &raquo;</TD></TR><TR><TD CLASS="quote">just want to compare to the stock ground control which is 350/280 front/rear
thanks
Search Results
Your search for stock spring rates returned 6 results.
https://honda-tech.com/zerothread?id=393982
https://honda-tech.com/zerothread?id=331354
etc.
Old Jan 15, 2006 | 04:47 PM
1GreyTeg's Avatar
So you want to revalve the Konis?
And Lift Oversteer can be induced easily in stock form. I don't understand what you're getting at there. I also don't understand when you say it's too harsh with Koni yellows. You mean the springs are too harsh? What's the purpose, daily driving?
choiboi
Suspension & Brakes
Apr 9, 2008 12:30 PM
teddy_dc2
Suspension & Brakes
Aug 13, 2007 01:04 PM
vinuneuro
Suspension & Brakes
12
Jun 26, 2006 08:47 AM
alj
Mar 9, 2005 06:51 PM
ninetfivehatch
Jun 3, 2002 03:59 PM
