check engine 1,3,9 no vtec help
Old Jan 15, 2006 | 04:18 PM
beaneg6's Avatar
Default check engine 9 help me!!!
check engine 9 cylinder sensor help me!!!!!!!!!
Modified by beaneg6 at 10:50 PM 1/20/2006
Old Jan 15, 2006 | 04:53 PM
beaneg6's Avatar
Default Re: check engine 1,3,9 no vtec help (beaneg6)
help me i need vtAKKK!
Old Jan 15, 2006 | 05:07 PM
BokChoy's Avatar
you're likely in limp mode with all of those codes, that explains the no "vtak"
Old Jan 15, 2006 | 05:13 PM
beaneg6's Avatar
Default Re: check engine 1,3,9 no vtec help (BokChoy)
isnt limp mode also called "safe mode" dont you have a very low redline? and can someone help me on how to get rid of check engine code 9???
Old Jan 21, 2006 | 11:44 PM
beaneg6's Avatar
Default Re: check engine 9 help me!!! (beaneg6)
some help would be greatly appreciated!!!
Old Jan 22, 2006 | 01:39 AM
beaneg6's Avatar
[QUOTE=beaneg6]check engine 9 cylinder sensor help me!!!!!!!!!
Old Jan 22, 2006 | 11:10 AM
czapp's Avatar
I had that problem w/ mine
If your vtec isn't working because of this it means you need a new VTEC sylonoid
to have Honda work on it it'll cost about $900
it sucks.
Old Jan 22, 2006 | 11:17 AM
BB6racer's Avatar
Default Re: check engine 9 help me!!! (czapp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by czapp &raquo;</TD></TR><TR><TD CLASS="quote">If your vtec isn't working because of this it means you need a new VTEC sylonoid</TD></TR></TABLE>
no he just needs to get rid of the CEL. "limp mode" is preventing VTEC from kicking in, not a bad solenoid. you will have to check the cylinder sensor, and fix whatever is wrong. hope you have a manual handy, cause i don't even know what/where the cylinder sensor is. is it the same as a knock sensor?
Old Jan 22, 2006 | 05:40 PM
beaneg6's Avatar
Default Re: check engine 9 help me!!! (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">
no he just needs to get rid of the CEL. "limp mode" is preventing VTEC from kicking in, not a bad solenoid. you will have to check the cylinder sensor, and fix whatever is wrong. hope you have a manual handy, cause i don't even know what/where the cylinder sensor is. is it the same as a knock sensor?</TD></TR></TABLE>
ok i have vtec again but i still have check engine 9 cylinder sensor...can someone help me with this damn thing!
Old Jan 22, 2006 | 07:11 PM
SteveoBA8's Avatar
DOWNLOAD/BUY A FNING MANUAL , then follow the flow chart.
Old Jan 22, 2006 | 07:48 PM
mayhemdestroy's Avatar
Code 9 (CYP) sensor, Its a sensor in the distributor! I had this problem for a while and FINALLY got rid of it.Look at this https://honda-tech.com/zerothread?id=993141
smurfylee
Sep 18, 2008 02:23 PM
ef9tuner
Apr 13, 2008 06:55 PM
bigdonnyboi
Mar 7, 2007 05:18 PM
xtreme-customz
18
Dec 1, 2005 07:51 PM
FleXingMyEK
Jun 2, 2003 06:02 PM
