Cell 22, Type R, help please
For some reason or another my check engine light keeps coming on when its cold outside and i start my car. Seems to only come on after a chilly day outside. It will drive fine and start fine but the code comes on. Then after i let the car warm up for 1-2 minutes and turn it off then turn it back on the code dosnt come on.
99 Jdm Itr Motor
p28 ecu, hondata
code 22 on cold start-up's
any-1 know how to fix this or what causes this?
99 Jdm Itr Motor
p28 ecu, hondata
22 92-98 Civic
93-98 Prelude
94+ Integra VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
* invalid code for non-VTEC engine
Does the car have enough oil?
93-98 Prelude
yea, oil is right on the mark
if it comes on when i start i can turn the car off like 1-2 mins later and turn it back on and it will not come back on and vtec will enguage
ok, i have the jdm swap so i was told to ground the vtec pressure sensor wire to the chasis of the car, i did that and the problem went a away for a while but now sense it got cold outside it seems to come on when its cold
could this be from a bad ground source?
should i just turn off the cell through hondata sense my JDM swap dosnt have the switch anyways?
99 jdm itr swap
93 del sol si
conversion wiring harness
p28 ecu
hondata
vtec pressure switch "orange wire" is grounded to chasis of car"
93 del sol si
p28 ecu
hondata
