could my idle problem be the EGR Valve?
Old Jan 14, 2006 | 01:37 PM
r1de4life's Avatar
Default could my idle problem be the EGR Valve?
My car is Idleing funny sometimes. Its not all the time but sometimes its does it like when i come to a light and stop it will do it or if i go to park in a spot it will also do it. The CEL came on and i ran a code on it and it said the EGR valve. Could this be the problem or not?
Old Jan 14, 2006 | 01:43 PM
6E LUDE's Avatar
It could be. Maybe just the gasket on it is worn out. The pipe to it is cracked/leaking? What was the code number?
Old Jan 14, 2006 | 03:10 PM
r1de4life's Avatar
Default Re: (6E LUDE)
I think its code 12. and im not sure if the pipe is leaking. and its OBD1
Old Jan 14, 2006 | 03:28 PM
lude98SH's Avatar
Default Re: (r1de4life)
if im not mistaken the egr valve is only opened when the throttle is opened. I would clean out the egr valve anyway if your pulling that code and see if it helps any. but most of the time your idle problem will be related to a bad or clogged iacv, so maybe clean that out too. Both are fairly easly jobs.
Old Jan 14, 2006 | 03:45 PM
racericky's Avatar
some times the EGR gets stuck open, I would disconnect the hose and plug it then see if it still continus. I think that thats the prloblem because it is dumping exhaust gasses to you intek side. causing it ti miss fire or hesitate.
Old Jan 14, 2006 | 03:49 PM
racericky's Avatar
dont trip if the CEL comes right up. that is telling you that the EGR is not working. just drive it for a cople of dayes to see if it dosnt Idle funny agen. If it dosent the EGR is you problem.
d_EG COUPE
19
Jun 21, 2009 07:02 PM
InvaderTrax
Jul 4, 2007 02:55 PM
Tip14
Jun 26, 2007 06:08 PM
yoffer
May 31, 2007 11:54 AM
Ricey McRicerton
Mar 19, 2004 09:11 AM
