HELP WITH FOG LIGHTS...!!!
Old Jan 13, 2006 | 09:23 PM
egcivic611's Avatar
Default HELP WITH FOG LIGHTS...!!!
i got the oem style fog lights and hooked them up. before putting the bumper back on, i checked to see if they worked (at this time i only had the left one plugged in)--it worked. so I plugged the right one in, put bumper back on, went to try them again, and now it just blows the fuse. i thought that maybe i pinched some wiring somewhere, so i removed the bumper again and checked and replaced it carefully to make sure nothing was pinched. still had the same problem. then i decided to unplug the right fog light and see if just the left one would blow a fuse...this time the left one worked and no fuse was blown. so i tried it the other way around with just the right one plugged in and it blew the fuse again..any ideas what is wrong?!?!?! all the wiring is correct (it came prewired as a harness, everything was plug and play. all the grounds are fine. i cant think of anything thats wrong..maybe that fog light it just busted?? help me out please!!
Old Jan 13, 2006 | 11:29 PM
egcivic611's Avatar
Default Re: HELP WITH FOG LIGHTS...!!! (egcivic611)
anyone have any ideas?? its an extremely annoying problem so any suggestions would be apprecaited. thanks!
Old Jan 13, 2006 | 11:48 PM
VRD^sam's Avatar
Redo your wiring...i had the same problem with my EK foglights...
Old Jan 14, 2006 | 12:01 AM
egcivic611's Avatar
Default Re: HELP WITH FOG LIGHTS...!!! (d-swap)
redo as in take it all apart and then put it back on again? its just one big harness so im not really sure what that will do but i guess i can try it...i just dont understand why the right one blows the fuse but the left one doesnt....
Old Jan 15, 2006 | 12:03 AM
egcivic611's Avatar
up...still need help..anyone got any other ideas?
Old Jan 15, 2006 | 06:36 AM
Rahxephon's Avatar
does your came with all the kits that had relay? i just did my on my EK never had any problem...self explanatory instructions.
Old Jan 15, 2006 | 06:46 AM
Ninety5Ex's Avatar
Change the fuse under the dash that powers the lights to a 20. I think it is the one for the parking lights not sure.
Old Jan 15, 2006 | 08:03 AM
highroller54's Avatar
Default Re: (Ninety5Ex)
if it blows the fuse as soon as you plug the right light in, then the problem is in the right light. Take it apart either the bulb is **** or something is grounded out the power wire inside the housing.
Old Jan 15, 2006 | 12:49 PM
egcivic611's Avatar
Default Re: (highroller54)
thanks, yeah its just the right one that blows the fuse, ill take that one apart and check it out.
csmith21
May 16, 2010 11:50 AM
tyronne1126
Audio / Security / Video
Mar 17, 2010 10:39 PM
jiro
Honda Civic (2006 - 2015)
Jun 24, 2009 09:11 AM
thisboyjulio
Nov 10, 2008 03:50 PM
GsDAteg
Jun 10, 2006 10:25 AM
