Electrical problems. Needing some help.
Old May 15, 2010 | 01:21 PM
csmith21's Avatar
Default Electrical problems. Needing some help.
As of a week ago my front turn signals stopped working. They work as running lights still but when I signal either direction, the cluster lights blink fast, even after replacing both bulbs.
At the same time the signals stopped working, my ignItion wire that runs to the radio stopped working. And my dash clock is too dim to read unless I press a button on the clock and it lights up just a little more.
Anyone else ever come across this? And yes I've checked all my visible fuses.
Old May 15, 2010 | 03:35 PM
csmith21's Avatar
Default Re: Electrical problems. Needing some help.
My driver side signal started working on it's own, but I still have the other problems.
Old May 16, 2010 | 07:45 AM
fcm's Avatar
fcm
Old Fart
Are you talking about your front signal lights, [bumper lights] or the front side markers.
If it is the signal lights, [bumper lights] it is most likely a connection problem, either power or ground.
If it is the front side markers then it is probably a ICU problem.
Have you checked the radio acc. fuse, fuse 28 - 10A, [hot in acc. and run] in under dash fuse box? 94
Old May 16, 2010 | 11:50 AM
csmith21's Avatar
The bumper lights. And I'll check all my wiring again. Thanks man.
slammed em1
Jan 23, 2010 09:26 PM
88aeFC3S
Jan 3, 2010 11:38 AM
Capt. Jimbo McSubipants
May 21, 2009 09:15 AM
95silverteg
Sep 30, 2008 04:48 AM
YouGotHacked
Honda Civic (2001 - 2005)
Nov 16, 2006 09:52 PM
