crx not starting every once in a while
sometimes it will just crank than i will crank it again and it will start and die like 4 seconds later do the same thing 2 or 3 times and than it will start and run fine... other times it will crank maybe 2 times and start right up other times it will crank 4or 5 times than start
does this sound like a fuel pump problem or does this sound like an electrical problem?
p.s. sometime if it starts up and i go to give it gas right away it will die
most of the time its the main relay to the pump, not the pump itself. it seems like the pump is bad because the relay isnt telling it to turn on and start pumping.
do you know where the fuel pump relay is ?
i just bought a used dizzy from a kid i know that had a bad coil in it... i replaced the coil and it seemed to be working perfectly
ATEJ8FTW
Sep 24, 2006 08:43 PM
markD.
10
Aug 23, 2006 06:15 PM
spettinger
May 25, 2005 11:46 AM
