RPM drops only after tapping throttle
Old Jan 13, 2006 | 08:17 AM
bumthology's Avatar
Default RPM drops only after tapping throttle
Hi,
i have a strange problem
when i start my car my idles normal..
when i drive, and at the lights as i put it into neutral, sometimes the rpm stays at 1000-2000rpm ! it just stays up there while i'm in neutral and have stopped
the only way to get it downis if i tap the throttle just a lil'bit (less than 1cm even)
anynone know what cuold be wrong?
engine is a d16a8
thanks
Old Jan 13, 2006 | 08:23 AM
crxluv2's Avatar
Default Re: RPM drops only after tapping throttle (bumthology)
sticky throttle cable?
Old Jan 13, 2006 | 08:32 AM
Speed--Freak's Avatar
I had a 88 hf with that same problem.
I found a small rubber line on th im that had collapsed.
Old Jan 13, 2006 | 09:06 AM
Pee Wee's Avatar
Default Re: (Speed--Freak)
yeah i had the same problem. sticky throttle cable and throttle body
shabam
Dec 9, 2007 07:52 PM
EKSedAndy
Oct 10, 2007 01:09 PM
shabam
Oct 9, 2007 05:10 PM
Nameless Warrior
Feb 1, 2007 08:58 AM
si0385.
Feb 3, 2006 08:19 PM
