b16a to b16b?
hey everyone, im new to this forum and im also very new to hondas and tuning them as well. im interested in buying a 99-00 civic si. i was wondering if its possible to build a b16a to run like a b16b. what would i need for the build? head, cams, higher compression pistons, etc? would it even be worth it or should i just save for a b16b or b18c swap? thnx
a cheap way to get a b16b feel would be to get a b16a, put in the CTR(b16b) cams, valvesprings, complete intake manifold and a nice exhaust with header. it would save you a couple thousand dollars
you can have much more power for less money by doing just a little extra work.
i did that b16a setup before and it pulled up to 9krpms and ran 13.7 @102 in an EF hatch.
you can have much more power for less money by doing just a little extra work. i did that b16a setup before and it pulled up to 9krpms and ran 13.7 @102 in an EF hatch.
A true B16B is nothing but a de-stroked B18C. If you have the money, just get the B18C block, and run all CTR parts(piston, cams, im, etc). It's what's called a "poor man's type r". B16a's scream on CTR cams
I am about to boost my civic and want to uprate some of the internals. I too run a B16a.
When you say CTR cams. Which CTR do you mean? i know its a stupid question but the only CTR we have here is the new shape one, I think it has the k series engine?
Or can you put any ctr cams?
and where can you find these parts? i take it they are used parts yes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J1A1H »</TD></TR><TR><TD CLASS="quote">I am about to boost my civic and want to uprate some of the internals. I too run a B16a.
and where can you find these parts? i take it they are used parts yes?</TD></TR></TABLE>
You would need 98-00 Civic Type R head parts. These CTR's came with the B-Series motors. Check JHPUSA.COM or even JDMSHIT.COM should have some stuff for ya
E. Honda
75
Jan 24, 2003 01:42 PM
