code 22 vtec pressure in jdm b16a?
Old Jan 12, 2006 | 10:13 PM
EF8IGHT's Avatar
Default code 22 vtec pressure in jdm b16a?
im throwin a code 22 vtec pressure valve
i know my oil is toped off and my wiring is good because vtech was kicking in with my chiped ecu i brought ecu back to stock and now i get code 22
i heard something in another thread that jdm motors dont have a vtech pressure switch or something? https://honda-tech.com/zerothread?id=1003567
doesnt make any sence because i have the pressure valve on my motor
what could it be? maybe a dented oil pan i need some ideas!
Old Jan 12, 2006 | 11:43 PM
beyondspexj's Avatar
first off its vtec.
second, what do you mean you but the ecu back to stock? what ecu are you running? still the chipped ecu with a stock program now? double check the wiring
Old Jan 13, 2006 | 05:37 AM
88 rex's Avatar
Default Re: code 22 vtec pressure in jdm b16a? (EF8IGHT)
JDM motors don't have a vtec oil pressure switch. So, if you have an ECU that is looking for a pressure switch, like a p28, then it will throw code 22 if it doesn't see it. This will prevent you from hitting VTEC. All you need to do is splice two wires........d6 and a4. splice the line going to the vtec pressure switch into the one going to the vtec solenoid. It's really easy and it works. I haven't had any problems, along with anyone else who has done this.
EDIT: I just checked my wires. If you have a p28 then cut d6 and splice it into a4. Problem solved.
RB_EJ8
Aug 6, 2008 03:56 PM
keychild486
11
Apr 2, 2008 06:28 AM
LShatchie
19
Oct 3, 2006 07:04 PM
ek9800
Apr 4, 2005 12:42 AM
