Idle? Not for me...
So Ive been having a problem missing fourth. So I said to myself, dont miss this time, and what did I do? Slammed it into 2nd
. Well now my car wont idle. Its running fine just wont idle at all. I dont know if there is supposed to be slack in the throtle cable but there is a lot of play in it. Any ideas on what is causing this other than a horrible misshift.
Adjusted the cable. Now it idles but its not smooth idle. Then when it comes back down from a short rev it dies. CEL isnt on so I dont think its a sensor or anything.
Yea I do believe that is my problem. aw8e9;tyas;dg. Alright. So is this an easy job, as in a weekend or so in the garage with the engine still in the car? Or do I need to take it to the stealership? Also should I just get the Honda valves or do they make after market ones?
Check your compression/leakdown to verify bent valves. It is a fairly major procedure to replace them. There are aftermarket valves available.
Alright I got a CEL today I got a (72) Misfire Dection. This would probably be the cause of a bad valve. eh? Does anyone think my engine is toast or will it cost over 1000 bucks in labor/parts. Thanks for the input so far.
Yea you bent your valves. Gonna cost you a sh*tload unless you know how to do the work yourself. Anyways maybe this 1000 dollar lesson will teach you how to shift or to stop shifting like a madman. Sorry this happened and good luck to you.
Yea it diffently has, the reason for the misshift was because I wanted so bad not to miss 4th and GRABED that stick and threw it down hard. So the valves in cylinder 2 only are bent or could other ones also be screwed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod »</TD></TR><TR><TD CLASS="quote">Check your compression/leakdown .</TD></TR></TABLE>
Car Tweaker
Sep 13, 2009 08:28 PM
