no spark and fuel!
Old Jan 12, 2006 | 08:44 PM
92bluepreludeSi's Avatar
Default no spark and fuel!
i recently installed stage 3 cams in my car. now i dont have spark and fuel. I cant figure out why though. would the car alarm kill spark and fuel. My starter works. thats why im confused. I didnt know my alarm worked till a buddy of mine pushed a loose fuse in and the alarm turned on. My dad said that he heard the fuel going through the fuel rail before my friend pushed the fuse in. should i take out my car alarm and connect the original wires back up? its a BW 3000.
Old Jan 12, 2006 | 09:04 PM
RJonathan's Avatar
Default Re: no spark and fuel! (92bluepreludeSi)
Stupid Question but did you connect the ground on your valve cover and did you check all fuses? mostly the ECU fuse sometime call ECM. because you can crank the car with out the ECU fues blown or out.
Old Jan 12, 2006 | 09:15 PM
Default Re: no spark and fuel! (RJonathan)
yea i connected the ground to the valve cover. thx anywayz and checked all the fuses.
Modified by 92bluepreludeSi at 10:26 PM 1/12/2006
Old Jan 12, 2006 | 09:28 PM
ed_1's Avatar
Well start with the fuse your friend pushed in. Cause some alarms have a fuel cut off switch when the alarm is activated. And you said your car used to work, before your friend pushed the fuse in.
Old Jan 12, 2006 | 09:31 PM
Default Re: no spark and fuel! (ed_1)
yea i'll start from there. it has to be that stupid alarm. geez. thx buddy
hwyix
Audio / Security / Video
21
Jan 17, 2013 08:09 PM
Moch@
81
May 25, 2012 09:15 AM
Si-Samuri
Jun 13, 2009 12:50 PM
99d-series
Sep 24, 2008 07:53 PM
vietjdmboi
Mar 3, 2005 02:33 AM
