Car not wanting to start sometimes???
well here latley my car sometimes doesn't want to start, like i can go somewhere cut my car off and then later on go back and try to start my car and it doesn't turn over nor will it even click. the main relay is coming on and i can hear the fuel pump run. but when i go to turn the key Nothing. well today when it happend i turned the key and let out on the cluych and something clicks and then when i push the clutch back in it clicks again. here is some info on the car and what has been done.........
1990 Civic Si
1996 D16Y8 still obd-0
centerforce stage 2 clutch
comp. clutch 11LBS fly wheel
battery in back
as of right now i am using a 89 integra ECU PG7 my PW0 was fried. so if any one could help me out on this i would love it! if you need some more info on the car just ask. Thanks to any one who can help!
Isaac-
1990 Civic Si
battery in back
Isaac-
i guess there really isn't a "Tech" to Honda-Tech any more. every one just likes to bull **** about stupid stuff.
Bump
Bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si »</TD></TR><TR><TD CLASS="quote">ground wires good/tight on the starter?</TD></TR></TABLE>
Thats what I thought. When my grounding on the starter was loose, I had a hard time starting when I turn on and off.
ill take a look when i go out tomorrow!
Thanks to the 2 people that helpd, maybe there is still some Tech people.
Isaac-
Isaac-
Did you change anything recently?
What size wire is running from the battery to the engine bay? Double check all your grounds and make sure they're all really solid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">Did you change anything recently?
What size wire is running from the battery to the engine bay? Double check all your grounds and make sure they're all really solid. </TD></TR></TABLE>
the power wire is a "4" and the ground is an "8"
