pressure plate problems
i upgraded my clutch pressure plate and flywheel on my stock gsr flywheel there are 6 threaded holes and on my upgraded f1 racing flywheel there is 9 do i use all the threaded hole on my pressure plate witht he ones on my flywheel becasue the stock one only comes with 6 nuts now i need to purches 3 more can anyone help me out please i need my teg back on the road
I am pretty sure it has more holes so it will work with other years/models.
I would bolt it up same as the original was
if there are 9 holes in the flywheel, use 9 bolts. when I had my clutch/fw installed it took a little longer because they had to order the 3 extra bolts just like in your situation. flywheels can kill
