pressure plate problems
Old Jan 12, 2006 | 03:53 PM
IntegraJdmb18c1's Avatar
Default pressure plate problems
i upgraded my clutch pressure plate and flywheel on my stock gsr flywheel there are 6 threaded holes and on my upgraded f1 racing flywheel there is 9 do i use all the threaded hole on my pressure plate witht he ones on my flywheel becasue the stock one only comes with 6 nuts now i need to purches 3 more can anyone help me out please i need my teg back on the road
Old Jan 12, 2006 | 06:50 PM
jfoster's Avatar
Default Re: pressure plate problems (IntegraJdmb18c1)
I am pretty sure it has more holes so it will work with other years/models.
I would bolt it up same as the original was
Old Jan 12, 2006 | 08:22 PM
Default Re: pressure plate problems (jfoster)
so if i add more u think it will cause a problem
Old Jan 12, 2006 | 08:25 PM
acuracy r's Avatar
if there are 9 holes in the flywheel, use 9 bolts. when I had my clutch/fw installed it took a little longer because they had to order the 3 extra bolts just like in your situation. flywheels can kill
El Civ
Transmission & Drivetrain
Aug 23, 2010 08:58 PM
dtme46
Mar 7, 2009 11:07 PM
95_red_dc
Sep 5, 2008 02:38 AM
smokey2.0
Apr 26, 2003 09:51 PM
