b18c1 in my ek
Old Jan 12, 2006 | 03:12 PM
tor-scot's Avatar
Default b18c1 in my ek
alright guys i have a few questions, i can get my hands on a b18c1 i think 97-98ish for dirt cheap, i want to throw it in my ek (98 cdn si). heres the few problems, my buddy got the car (rear accident) so we got to take the motor out ourselves, this is a first for me! so what are some things i can leave behind that i dont need for my swap, the mounts and axles are no good to me, can i chop rad hoses and ****? im going to leave the wire harness in tact, what about the ECU, can i use it for my car? and i dont need the PS and AC cuz it wont fit in my car right? last question, i dont have papers for the motor and im out to lunch when putting it in my ride, will some shops install motors without papers? and do you think i can install it myself, my ride is obd2v1, i dont know what the b18 is yet, so its not plug and play right, any help for a noob guys?
thanks
Old Jan 12, 2006 | 03:22 PM
mluckxxx's Avatar
Default Re: b18c1 in my ek (tor-scot)
the motor will be OBD2
Old Jan 12, 2006 | 08:17 PM
tor-scot's Avatar
Default Re: b18c1 in my ek (mluckxxx)
that didnt help to much, anyone else. do i need to drop ac and ps? and can i use the axles from the gsr?
Old Jan 12, 2006 | 10:21 PM
im done's Avatar
you can't use the harness from the gsr but you can use the axles from the gsr. you also would need 99-00 driver side engine mount and the rear L bracket
Old Jan 12, 2006 | 10:36 PM
VRD^sam's Avatar
Default Re: b18c1 in my ek (imc2pid)
have fun!!!!
Old Jan 13, 2006 | 08:40 AM
tor-scot's Avatar
what about me not having papers, will shops install motors without papers?, and ps and ac, do i drop it? and what harness do i use then?
Old Jan 13, 2006 | 08:47 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (tor-scot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tor-scot &raquo;</TD></TR><TR><TD CLASS="quote">what about me not having papers, will shops install motors without papers?, and ps and ac, do i drop it? and what harness do i use then?</TD></TR></TABLE>
I don't see why they wouldn't. You have money, right? You won't need to drop ps/ac unless you want to. And you will need that ECU
Old Jan 13, 2006 | 09:20 AM
tor-scot's Avatar
so i can keep the gsr ecu and axles, get new mounts, keep my ac and ps, and just get someone to wire it up?
Old Jan 13, 2006 | 09:50 AM
hondahatchgsr's Avatar
I have a GSR in my EK. I have no A/C, depending on what you want to do with the car, if you want to save weight then leave the A/C off, also you can leave the PS off and save weight. It all just depends on what you want to do with it. The axels will work, I have a GSR tranny in it too. I kept the PS in mine cause its a daily driver. But for sure get someone to wire it all up for you if you don't really know what your doing. Enjoy the new engine, they are fun in EK's.
Matt
Old Jan 13, 2006 | 10:26 AM
Sloshy's Avatar
your in luck i just finish doing that swap to my ek hatch
heres whats you need, all the mounts are the same the only bracket that defintly changes is the rear t-bracket and the timing beltside bracket might be the same not sure i put 99-00 civic si on mine to be sure, the tranny bracket (top one) is exactly the same i had bad luck on this one cuz i went to the dealership and got a si one and found out they were identical when it was already install, for wiring harness just use 99-00 civic si for simplicity everything hooks up its an easy swap
funny how all the mounts are all the same
Old Jan 13, 2006 | 11:45 AM
tor-scot's Avatar
what if my mounts are the *****, its like almost all of my bushings are exploded! should i just replace all of them with 99-00 si? and how much will this cost?
Old Jan 13, 2006 | 12:16 PM
FuNkDrSpOt's Avatar
Default Re: (hondahatchgsr)
The Canadian Si is the U.S.'es Ex so you would just use the harness you already have. Your car is already wired for vtec so that eliminates one headache.
You'll need (from the gsr):
axles
ecu
engine/tranny (of course)
99-00 Si (US Si i believe) rear tranny mount
gsr front tranny mount
P54 ac bracket (should you want to keep ac)
99-00 Si driver side engine mount bracket ( the one that bolts to the engine by the timing belt )
shift linkage
My best recommendation for you would be to visit this forum's FAQ page at the top and to visit Hybrid honda ( http://tech.hybridgarage.com/t....html ). Hybrid honda had a more comprehensive link but for some reason its gone. I saved the page but I can't put it up here. If you need prices you should visit ( http://www.slhonda.com ) they have pretty cheap prices.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">The tranny bracket (top one) is exactly the same i had bad luck on this one cuz</TD></TR></TABLE>
The tranny bracket is not the same. The rubber mounts are but in no way is the tranny bracket the same. The gsr has a triangular bolt pattern while the D series engines have a 'L' shaped pattern. Also, the D series bracket is about 3mm too long, meaning you can connect the bracket to the tranny with 2 of 3 bolts but it's too long to bolt it up to the frame.
Old Jan 15, 2006 | 11:47 AM
Stephdavis18's Avatar
What you guys prolly dont take in to consideration is that in canada a civic si Is really thw same as a ex in the states...Im from california but Im laying hockey upp here and that what I found out.....the american si is what they call the sir up here...in that case hes gonna need everything for the swap...harness, ecu, mounts, tranny axels...the whole nine yards.
Old Jan 15, 2006 | 11:49 AM
FuNkDrSpOt's Avatar
Default Re: (Stephdavis18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stephdavis18 &raquo;</TD></TR><TR><TD CLASS="quote">What you guys prolly dont take in to consideration is that in canada a civic si Is really thw same as a ex in the states...Im from california but Im laying hockey upp here and that what I found out.....the american si is what they call the sir up here...in that case hes gonna need everything for the swap...harness, ecu, mounts, tranny axels...the whole nine yards.</TD></TR></TABLE>
did you not just read my post?
Old Jan 15, 2006 | 01:03 PM
swapsshonda's Avatar
Keep everything!!!!!I always do.Throw it away as time passes.you mite need some of the little #@$8.If that DC is a 97 and you rock a EK it should all be OBD 2.I wish i was fixing do that sounds fun.
Go EG!!!!!
Old Jan 15, 2006 | 01:08 PM
tor-scot's Avatar
my canadian si does not have v-tech so its not wired up for it, so do i use the harness and ecu from the gsr?
Old Jan 15, 2006 | 01:16 PM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">The Canadian Si is the U.S.'es Ex so you would just use the harness you already have. Your car is already wired for vtec so that eliminates one headache.
axles
ecu
shift linkage
The tranny bracket is not the same. The rubber mounts are but in no way is the tranny bracket the same. The gsr has a triangular bolt pattern while the D series engines have a 'L' shaped pattern. Also, the D series bracket is about 3mm too long, meaning you can connect the bracket to the tranny with 2 of 3 bolts but it's too long to bolt it up to the frame. </TD></TR></TABLE>
dont pay for the swap.. trust me! 800 bucks to install.. f that! save yourslelf the money and do it yourself. get a cherry picker and everything is down hillfrom there. not hard at all just 3 main motor mounts and 2 tranny mounts(i think cant really remember..) swapped my motor a long time ago. and as for the hoses plug right up. the only thing is to pay to get it rewired and presto you have your self a swap. have fun
Old Jan 15, 2006 | 01:27 PM
mugenpowered's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tor-scot &raquo;</TD></TR><TR><TD CLASS="quote">my canadian si does not have v-tech so its not wired up for it, so do i use the harness and ecu from the gsr?</TD></TR></TABLE>
Ya you are right, your Canadian Si does not have vtech, cordless phones were never an option on that model of Civic.
But you do have VTEC on your Si. They all came stock with that, it's just that on a d16 vtec is not noticeable.
Old Jan 15, 2006 | 05:15 PM
FuNkDrSpOt's Avatar
Default Re: b18c1 in my ek (e gee two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">dont pay for the swap.. trust me! 800 bucks to install.. f that! save yourslelf the money and do it yourself. get a cherry picker and everything is down hillfrom there. not hard at all just 3 main motor mounts and 2 tranny mounts(i think cant really remember..) swapped my motor a long time ago. and as for the hoses plug right up. the only thing is to pay to get it rewired and presto you have your self a swap. have fun </TD></TR></TABLE>
I know being a noob should have no bearing on how well you read english but this is twice today...I'm sorry but why quote me and talk about not paying for a swap? If it was in reference to me talking about slhonda.com that was for prices for things he might need for the swap, not to do the swap.
Also, i forgot to throw out http://www.acuraoemparts.com/delray/jsp/home.jsp
for all the acura stuff you might need to pick up (pumps, hoses, thermo, etc.)
Old Jan 15, 2006 | 05:55 PM
Ls_V_TurboSi's Avatar
Default Re: (mugenpowered)
do the swap yourself. Swapping a motor is cake. Just make sure you have everything needed before you start. I wouldnt cut anything, dont be lazy pull the motor out the right way. all the extra **** you dont need just sell.. Do some research
Old Jan 15, 2006 | 06:20 PM
tor-scot's Avatar
does anyone have a link to a page where it can tell me how to properly take it out with a cherry picker?
Old Jan 15, 2006 | 06:24 PM
why dont you just remove it? It will be alot easier..
Old Jan 15, 2006 | 08:45 PM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">I know being a noob should have no bearing on how well you read english but this is twice today...I'm sorry but why quote me and talk about not paying for a swap? If it was in reference to me talking about slhonda.com that was for prices for things he might need for the swap, not to do the swap. </TD></TR></TABLE>
first of all i quoted you for the things you need for the swap and thats it
second of all i said to do the swap himself because thats in my own opinion it had no reference to what you were talking about!!
it had nothing to do with the your quote. if your quote didnt say anything about doing the swap himself why do you think that i would say something like that.. wow just cause i havent posted as much as you makes me a noob?
maybe i should have started it off different for you
want2drive
Jun 14, 2011 10:11 AM
spags930
May 20, 2010 11:14 PM
1992hondacivicvx
Nov 28, 2009 04:54 PM
JDMEK187
Oct 2, 2007 08:25 PM
LongJon
14
Jan 11, 2007 07:33 PM
